A Light problem
Old Jul 12, 2009 | 07:56 PM
Low Ufo's Avatar
Low Ufo
Default A Light problem
Hi
'02 Coupe
I've got a problem with the passenger side light. Click the switch, both lights open up with no problem. Go to shut the lights off, the driver's side closes with no problem, however, the passenger side closes and the motor keeps "grinding" away for around another 10 seconds - AFTER the light is down!
What's wrong, and how can I fix it? (Sorry if it is a dumb question, but I've never had this happen before.......)
Thanx
D.
Old Jul 12, 2009 | 11:03 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
you're headlight lifting motor gear is busted. Replace it with a brass one for about $50 and the problem will go away.
estimated project time: 1-2 hours
Old Jul 13, 2009 | 01:10 AM
DeeGee's Avatar
DeeGee
Run down to the section on headlights in this sticky and you'll find all you need to replace them
http://forums.corvetteforum.com/c5-g...ngths-etc.html
Old Jul 14, 2009 | 07:27 PM
Low Ufo's Avatar
Low Ufo
Thanx Guys !
A set is now on order!
To A Light problem
