Window Valet problem
Old Jul 19, 2009 | 11:50 PM
T&C Conv's Avatar
T&C Conv
Default Window Valet problem
I have a Window Valet which works OK, but I have an intermittent problem.
When I press the lock button 3 times, the windows roll up, but after about a second, the windows roll down. This is an intermittent problem and after 2 or 3 failures, it works properly. The other day I used it and the windows rolled up and stayed up with the first attempt. When I came out, the drivers window was down, and the passenger window was up. I no longer trust it and roll up the windows before I get out and lock it.
Has anyone else had this problem or any ideas?
T of T&C
Old Jul 20, 2009 | 12:07 AM
dodriven's Avatar
dodriven
I was planning on ordering one, but i'll wait to see how this thread goes.
Old Jul 20, 2009 | 12:29 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You might have to calibrate the "strength" -
You'll press '1' on the DIC to access the window
configuration options.
Under the '1' options, there's four more items:
1 - disable
2 - enable and calibrate
3 - window up strength, normal
4 - window up strength, strong
You'll press '2' on the DIC to enable and calibrate the
windows. This option requires a pin number. The last
paragraph of the disclaimer describes the relationship
between the PIN number and the serial number. The
serial number is on the disclaimer page and on the unit.
Please be sure you've read the disclaimer.
To enter the pin number, just key it in on the DIC.
The sequence:
1) Get into configuration mode by holding 'reset' and
pressing 'unlock.' You'll hear a triple chime and see the
tach move to 1K RPM.
2) Press the '4' button. Tachometer goes to 2K RPM.
3) Press the '1' button. Tachometer goes to 3K RPM,
speedometer goes to 10 MPH.
4) Press the '2' button. Tachometer goes to 6K RPM,
speedometer goes to 40 MPH.
5) Enter the PIN number. (See the disclaimer.). Each
time a digit is read, the speedometer needle will
increase by about 10 MPH. If you press a digit and the
needle doesn't move. Press it again, completely.
If all is accepted, the windows will drop to the bottom
completely. The horn will toot to warn that the windows
are about to go up. The windows will go up completely.
Once everything is settled, you should be able to raise
and lower the windows with three clicks of the remote
(three ‘locks’ to raise; three ‘unlocks’ to lower).
I've had a Window Valet in my car for years and have had no issues with it.
All of the instructions on the features and the calibration is on their site.
http://www.topdowntech.com/documents/WV-100.pdf
We have the Window Valets for sale for the C5, C6 and many of the GM trucks. We sell them for $129.99 plus shipping.
BanditDude's Avatar
BanditDude
One of my windows is starting to drag a bit more than the other. Probably a weakening motor. As such, I've had to re-calibrate the window valet. It worked fine once it "learned" the speed of the window.
Old Jul 20, 2009 | 12:37 AM
DeeGee's Avatar
DeeGee
That'll fix it
Old Jul 20, 2009 | 01:49 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Rands to the rescue!
1 - disable
The sequence:
Old Jul 20, 2009 | 01:56 AM
TooMch's Avatar
TooMch
I've had a similar experience. Plus a few times, I "thought" I watched the windows go up and stay up, only to come out and find them down. Then I wonder did I really watch them go up and stay. Every time I concentrate on watching, I have no problems or should I say no surprises. Once in a while they come back down momentarily after going up. If I close them again they stay. I haven't tried calibrating the strength. Guess thats on the to-do list.
Old Jul 20, 2009 | 02:14 AM
WildTurkey's Avatar
WildTurkey
Forum rocks! Nice RANDY
Old Jul 20, 2009 | 02:21 AM
MYLS6's Avatar
MYLS6
subscribed since I just bought a used one and wont be able to use it till I get home end of year
Old Jul 20, 2009 | 08:24 PM
T&C Conv's Avatar
T&C Conv
Thanks guys, I will try it tonight.
Old Jul 20, 2009 | 08:46 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Geez Randy, you could have given the guy a little bit more to go on rather than providing such a vague answer
First class buddy
OP, let us know how you make out
Old Jul 20, 2009 | 09:26 PM
Stevo92z28's Avatar
Stevo92z28
wow thats really strange. Same exact thing happened to me this morning. I had just bought this used couple weeks ago...thought there was a problem with it. I will have to calibrate later.
Old Jul 21, 2009 | 12:04 AM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
That should fix it. BlackSedan
Old Jul 22, 2009 | 03:09 PM
srs244's Avatar
srs244
St. Jude Donor '09 thru '26
i've experienced the same thing, and i HAD calibrated the device before it started to happen. i pay real close attention to it now just like you. unfortunately when i discovered it the first time it was in a parking lot and had been left alone for about 3 hours. fortunately nothing was out of place or missing. i'm not certain i trust it completely at this point, however.
To Window Valet problem
