Exhaust plate
Old Jul 23, 2009 | 02:48 PM
Florida Mike's Avatar
Florida Mike
Default Exhaust plate
So do all of the available logo exhaust plates just mount with double face tape? Seems maybe underneath thats not the best mounting method with water, heat, etc.
Any thoughts? Just don't want to spend $45 for one only to have it fall off one day and I will never know it until I am long down the highway.
Old Jul 23, 2009 | 02:53 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
shouldn't be a problem if you prep the area properly. i had one on for well over 2 years without a problem (yes i live in south florida and we have loads of rain and heat here also, lol), i had to remove it when i changed my exhaust system and the available space changed. i found another that i could make work after the exhaust change out and that's been in place (with double sided tape) for well over a year. if you are uncomfortable with the couple of strips that come with the plate you buy, go to your local NAPA or other auto parts store and get some 3m trim double sided tape and add a couple more pieces in appropriate spots.
Old Jul 23, 2009 | 02:55 PM
DeeGee's Avatar
DeeGee
The double sided tape works great. Just prep the area properly
Old Jul 23, 2009 | 02:58 PM
hector88's Avatar
hector88
^ yup ive had mine for a little under 3 yrs... i had the same fear when i first bought mine that y i made sure i preped the area properly
Old Jul 23, 2009 | 03:07 PM
BlueDream's Avatar
BlueDream
With a properly cleaned area, the double sided tape will stick (the tape they provide with most of these plates is not your standard double sided tape - it is much stronger). I've had mine on the car for over 6 years now and it won't even think about coming off. You should be more concerned about making sure it is straight and in the right place before you stick it on because you are going to have a very hard time removing it.
Old Jul 23, 2009 | 03:09 PM
Trpblk04's Avatar
Trpblk04
Once you install you will see, that tape is no joke...
Old Jul 23, 2009 | 03:31 PM
Florida Mike
Cool! Thanks guys!
Old Jul 23, 2009 | 03:36 PM
lil vette's Avatar
lil vette
Or you could have a hitch put on & tack weld to some square stock
& slide into the hitch......Worked for meeee
Old Jul 23, 2009 | 04:09 PM
jrose7004's Avatar
jrose7004
That's it.
Old Jul 23, 2009 | 05:24 PM
Bills03Coupe's Avatar
Bills03Coupe
I'll second making sure it's straight. Once this stuff makes contact on a properly cleaned and prepped surface, it's not going anywhere!
Old Jul 23, 2009 | 06:30 PM
Mine mounted with double sided tape and was still solid as a rock after 6 years on the car. Just clean the mounting area up very well and it will last for a long, long time.
To Exhaust plate
