C5 door panel delaminating
Old Aug 7, 2009 | 02:45 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Old Aug 9, 2009 | 01:57 PM
Humy's Avatar
Humy
Hey dudes,
I have a pair of black door panels I want to unload. No material peeling or bubbling, just some small knicks. If interested, PM me and I will send you pics
Old Aug 9, 2009 | 02:17 PM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
Ha join the club...
Mine are disgusting
Old Aug 9, 2009 | 03:28 PM
SharpCrease's Avatar
SharpCrease
Originally Posted by LoudassZ
Ha join the club...
Mine are disgusting
Mine seem perfect but PLEASE SOMBODY TELL ME HOW TO PREVENT THIS..... I use VinylEx to condition it.
Old Aug 9, 2009 | 04:34 PM
DeeGee's Avatar
DeeGee
Ha join the club...
Mine are disgusting
Wow, thats serious!
Old Aug 9, 2009 | 06:34 PM
Humy's Avatar
Humy
I use Aerospace 303 and use sun shades to keep sun out of the cockpit - I even put them up on the passenger side windows depending on time of day people at work think I am crazy
Old Aug 9, 2009 | 10:20 PM
CLEAR's Avatar
CLEAR
Whatever you all do, dont use super glue. Dont ask how I know. Definately needs to be something you can spread around.
Old Aug 14, 2009 | 05:43 PM
Old Rotor Head's Avatar
Old Rotor Head
Mine are shot in the arm rest and above. Does VE or DS make C5 panels? I've only seen C6.
Old Aug 14, 2009 | 06:27 PM
TEXHAWK0's Avatar
TEXHAWK0
I think the vinyl covering must shrink.
I can push mine in and tell the adhesive is still sticky. It is just not strong enough to hold it stretched into place in the corners.
I guess the ultimate fix is to recover the panels with real leather like I saw a forum member do.
Old Aug 14, 2009 | 11:45 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
I've been considering looking into getting panels made out of REAL leather and ditching the "tupper ware".
Old Aug 15, 2009 | 12:08 PM
my6thvette's Avatar
my6thvette
What is the problem with super glue? I once used it to glue down the front of the dash pad on an old Lumina APV van. Nothing else worked. I have been wondering if it might be possible to inject super glue or super glue gel under the the separated skin using a hypodermic needle and syringe and then spreeding it out by gently massaging the separated skin back into place. Just a thought.
Old Aug 15, 2009 | 02:33 PM
CLEAR's Avatar
CLEAR
Thats what i did. Super glue wouldnt spread. Turned out looking worse.
Old Aug 15, 2009 | 02:37 PM
  #33
Old Rotor Head
Went to the local restoration shop today. This guy does RR, antiques, etc from all over the country, first class craftsman. $600 for both sides in leather, doubled stitched and he takes the panels off and reinstalls them. Not cheap but I know that the stick on arm rest fix for $150 won't work for me, I may just bite the bullet.
He will also do my center console, and, and.....it's just time and $$
Old Aug 15, 2009 | 02:44 PM
  #34
craig04c5's Avatar
craig04c5
What's the name of the shop. I may want to do the same thing. Let us know if you do it and how they turned out.
Old Aug 15, 2009 | 04:10 PM
  #35
ZO6Bear's Avatar
ZO6Bear
I have a problem with the whole leather thing. Don't they have to glue the leather down? If they glue it to the black stuff that is already coming up won't that just lead to the leather coming up?
Old Aug 15, 2009 | 06:29 PM
  #36
Old Rotor Head
http://www.hoytsautoupholstery.com/
FYI, the vinyl is stripped and the underlayment repaired if necessary. There will be crafted stitching where seperate panel are required because of the contours.
I've got one other shop in Sarasota I want to check with Monday.
Old Aug 15, 2009 | 07:04 PM
  #37
TEXHAWK0's Avatar
TEXHAWK0
This guy made new leather panels for his doors.
http://forums.corvetteforum.com/c5-g...-the-c5-4.html
http://s678.photobucket.com/albums/v...schedriver986/
To C5 door panel delaminating
Old Aug 15, 2009 | 07:18 PM
  #38
Old Rotor Head
Originally Posted by TEXHAWK0
Boy not me, I'd have one He!! of a mess on my hands.
Old Aug 15, 2009 | 09:02 PM
  #39
stingraymyway
That's not too bad, considering the time and craftsmanship put into doing that type of work. Not to mention that it's more expensive to replace the panels with OEM that'll eventually do the same thing.
Old Aug 18, 2009 | 03:09 PM
  #40
kikicorvette's Avatar
kikicorvette
Originally Posted by LoneStarFRC
That seems to be a pretty good price (depending on the exchange rate and the quality of the work).
Give us a heads up on how things turn out.
I am seriously thinking along these line as the ultimate solution as well. Of course there's also the "bling" factor too. I'm thinking all black with silver stitching to match the silver stitching on my seats and keeping my tutone VE (black/silver) door pulls and tutone VE armrest pads.
here i am
My door panels are almost finished
some pics
