Mobil 1 question?
Old Aug 1, 2009 | 12:22 PM
robsc501's Avatar
robsc501
Default Mobil 1 question?
Hi There:
I was wondering why Mobil 1 fully synthetic 10w-30 does not say that it meets the GM 4718m spec. Only meets the GM 6094m. The 5w-30 f/synthetic meets both specs. gm4718m,gm 6094m . I just checked this today, looking at the 5 qt. container. I wanted the 10w-30 weight but bought the 5w-30
robsc501
Old Aug 1, 2009 | 12:31 PM
Donkey's Avatar
Donkey
Strange...this page says https://www.mobiloil.com/USA-English..._1_10W-30.aspx
Mobil 1 10W-30 exceeds warranty requirements for gasoline engines where an API certified oil is specified. It meets:
ILSAC GF-4 (API Certified - Starburst)
API SM/SL
GM 6094M/GM4718M
Requirements for Diesel Powered Vehicles where an API CF or API CD is Recommended
ACEA A1/A5, B1/B5
Mobil 1 10W-30 is recommended for all types of modern vehicles, including high-performance turbo-charged, supercharged gasoline and multi-valve fuel injected engines found in passenger cars, SUVs, light vans and trucks.
Mobil 1 10W-30 is general purpose engine oil for all types of vehicles where a 10W-30 viscosity is recommended.
Mobil 1 is not recommended for 2-cycle or aviation engines, unless specifically approved by the manufacturer.
For more information, see the Mobil 1 10W-30 Product Data Sheet and the Material Safety Data Sheet.
Old Aug 1, 2009 | 01:11 PM
robsc501's Avatar
robsc501
Hi There:
Thanks for the link. I read that.But thats not whats on the label. 4718m for the 10w-30 is not there,but 6094m is. You,re right strange. I was in Walmart this morning $22 for 5qt. container.
robsc501
Old Aug 1, 2009 | 01:16 PM
VinnyT's Avatar
VinnyT
http://www.gm.com/corporate/responsi...ngine_oils.pdf
I use Castrol Syntec in mine. 10w-30 summer, 5w-30 winter.
Old Aug 1, 2009 | 01:17 PM
SCM_Crash's Avatar
SCM_Crash
I know I'm going to get flamed for this, but if you've never used anything other than Mobile1, give either German Castrol 0w30 or Amsoil 0w30 (the oil I use) a try. You'll be pleasantly surprised how quite the valve train will be and how much smoother the car will feel.
Just my 2 cents...
Oh, Amsoil is truly the best oil there is. It's used in race cars, but it does cost a bit more than others (at 9.xx / qt).
Old Aug 1, 2009 | 01:18 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Whats the reason for using 10-30?
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I run 5W-30 all year, even in the summer. I live in Phoenix where we just had the hottest July on record....and I still use 5W-30. Stick with it and you'll be fine.
Old Aug 1, 2009 | 01:20 PM
VinnyT's Avatar
VinnyT
Better viscosity when running it in really hot temps.
Old Aug 1, 2009 | 01:31 PM
Patman's Avatar
Patman
This is no longer an issue when it comes to modern synthetics though. A 5w30 conventional oil will thin out a lot quicker than a 10w30 conventional, but when it comes to synthetics that doesn't happen.
In the oil analysis reports I've gotten with Pennzoil Platinum 5w30, the final viscosity ends up being 11 cst at 100c after 7000 miles, exactly the same viscosity the oil starts out as when new. So it's not thinning out whatsoever. IMO, 10w30 synthetic is obsolete, as 5w30 can do everything it can do, with the added benefit of flowing better when cold.
Old Aug 1, 2009 | 01:33 PM
robsc501's Avatar
robsc501
HI There:
VinnyT: Thanks for the link. I looked at it.Appears to me thats its a label problem as the 10w-30 definitely meets the spec. 4718m.
robsc501
2KFRC5's Avatar
2KFRC5
Oh no, Mr. Bill.
Old Aug 1, 2009 | 03:44 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Originally Posted by robsc501
Hi There:
robsc501
Its possible that bottle was made while Mobil had a PAO basestock interuption during their plant failure last year. They might have had to temporarily change the formulation slightly and lost the GM 4718M certification. Although I'm with Patman and feel that a 10w30 isn't really needed these days, I suspect if you check the bottles, you'll find one with the 4718M on it sooner rather than later.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Aug 1, 2009 | 04:04 PM
killain's Avatar
killain
Oldtimer
Hi There:
robsc501
Hay Rob, I don't think you have got a 'Mobil 1 Synthetic oil container. I have a Mobil 1 Synthetic Motor oil 5 quart container, worlds leanding synthetic motor oil in front of me right now, and on the back, 2/3 of the way down the back it says: it meets or exceeds, GM 4718M, GM6094M, chrysler MS6395 Ford WSS-M2C929-A Honda/Acura HTO-06, also it's ILSAC GF-4 API SM SL/CF It goes on to say if you have any questions call 1-800-ASK-MOBIL or visit www.mobiloil.com. I don't know what to say, it's sitting no more than a foot from my keyboard? I'm getting ready to change the oil next week. And it's the Motor oil used in Nascar engines and it's Factory fill for ALL corvettes including the new ZR1 as well as all Porsche models built. If it's OK for Porsche, and all Corvettes built, It sure is OK by me. All those chemical engineers can't be wrong
Old Aug 1, 2009 | 05:05 PM
robsc501's Avatar
robsc501
Hi Jim:
My 5qt. 5w-30 says the same as yours. I,am just saying the 10w-30 container did not.
robsc501
Old Aug 1, 2009 | 06:18 PM
killain's Avatar
killain
Oldtimer
Hi Jim:
robsc501
Hi Rob, Maybe due to the hurricane Katrina, and the disruption of Mobil facilities down there that you got a 5 qt container with a misprint ? Wouldn't be the first time I've seen that happen ! Hope everything works out OK for you. I used to use the Mobil 1 10w/30 and at Corvettes at Carlisle one year I got talking to a Mobil engineer and he convinced me that using 5w/30 was much better due to where I live, (Cold winters) and since then I just always buy the 5w/30 at Wallys place. Usually cost me $29.97 for 7 quarts. Good luck buddy !
Old Aug 1, 2009 | 07:23 PM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
I've used Mobil 1 synthetic but switched to Castrol synthetic on my last oil change, 5w-30.
Both oils I'm sure work very well. I asked my mechanic why he switched brands. He said something I thought was very interesting and on the surface made sense, but I really don't know if it is true or not. He said that each manufacturers oil contain different chemical properties ; that by swiching oils ypu will have the benefit of a wider spectrum of chemical properties and that was better for an engine than just being exposed to a few chemical properties in one oil. This kinda made sense to me but I don't know if it has merit.
777
Old Aug 2, 2009 | 01:18 AM
Dave68's Avatar
Dave68
I did the same a few years ago when I called Mobil. Their tech guy to whom I spoke told me that 10W-30 synthetics are essentially obsolete. That viscosity oil cannot "pump up" as quickly as a 5W-30 during startup, even when the temp is 70 degrees F.
So stick with 5W-30, 0W-30 or even 0W-40 synthetics and forget about old school 10W-30.
To Mobil 1 question?
Old Aug 2, 2009 | 02:18 AM
atmsrus1's Avatar
atmsrus1
anyone know anything about Royal Purple oil, I am about to get mine changed and thought about going with it... Any Suggestions.....Using Mobile 1 right now,,
Thanks,
Russell
Old Aug 2, 2009 | 03:11 AM
karateboi87's Avatar
karateboi87
Originally Posted by Dave68
I did the same a few years ago when I called Mobil. Rgw tech guy to whom I spoke told me that 10W-30 synthetics are essentially obsolete. That viscosity oil cannot "pump up" as quickly as a 5W-30 during startup, even when the temp is 70 degrees F.
I saw that 0W Mobil at walmart for same price (forgot if it was 30 or 40).
Do these (either 30 or 40) work for our vettes? Anyone tried them? They are new to the market but it seems promising.
Old Aug 2, 2009 | 06:48 AM
rws.1's Avatar
rws.1
Hi There:
robsc501
You didn't grab the wrong version did you??
The Extended Life version of Mobil 1 does not meet GM4718M
