Best Radar Detector???
I live in a huge metropolitan area. Keep in mind that you can "tune" your V1 to suit your preferences (turning X band off, for example) which will greatly diminish false alerts.
Personally, I prefer a radar detector that is more sensitive, and may false a time or two (on account of a supermarket door or what not) but inform me well before I encounter a real threat.
I still use my RX65 on my motorcycle, and even though it's a great radar detector, I feel totally naked with it. There is no comparing it to the V1.
Yes it's old technology, but it still works the best!
Modern jammers do not give the cop a false reading, or an error code. They simply give him nothing. The proper use for a laser jammer is to alert you, give you a few seconds to slow down, and then you disable it (via a killswitch) so that the cop can get a reading on you but by now you're only doing 5-10 over the limit.
There is no fool proof system, but increasing your knowledge on the subjects is what saves you from tickets.
I run a V1 combined with Blinder M25 laser jammers. I know exactly what local cops are running and know what to lookout for. I don't get mad when my V1 "falses" a K band alert because I know the chances of that being a police gun are next to nothing, and I have the mute button easily located so I can quickly stop it from chirping.
The V1 sensitivity has saved me many times and the arrows are simply invaluable. I know when my radar was being triggered by a cop driving in the opposite direction, hiding in the bushes behind me, or is way down the road which no other detector gives me.
And if your local enforcement runs laser, then a radar detector won't give you anything other than a "you now have a ticket" alert.
If I money was no option I would go with a hardwired Valentine 1 and Laser Interceptor jammers.
Certain guns with certain jammers can pick up an error code, but it's not like older jammers which would just blow out any reading that the old gun would get. Current jammers are designed to pick up the pulse rate of the gun, identify it, and respond with the same pulse rate so that the gun think's it just hitting a non-moving object.
It's not a flawless technology, but I've had mine pay for themselves at least 3 times over by now. Even if it gives me a few seconds before "punchthrough" (When the gun gets a reading), thats enough time for me to get my speed down and potentially save me from the ticket.
The biggest issue is surface area on a car. Big cars with big headlights and lots of chrome are the worst target because they reflect the most. A C5 with the lights down, no front plate (giant mirror to IR) and jammers would be nearly invisible (despite being a target for speeding otherwise).
In the past I always had some sort of detector in my cars. Wouldn't leave home without it. Apparaently the K 40 is pricey but features front and rear detection units and a seperate front "stealth" laser diffuser (looks like easypass). Can't say I every heard the diffuser go off though, lucky I guess. Overall the unit is very impressive in it's sensitivity.
