I have white LED flood lights mounted into the location where the export model's parking lights are (just to the outside of the fog lights) they work amazingly well! I also have white LED strips mounted inside the brake ducts. they are thin and fit where you can't see them at all when they're off. not as bright as I wanted when they are on but you can see them here:
what you are looking at there is not the fog lights! they are much brighter. those are 1 Watt LED flood lights, one on each side
here's a closeup
I have them wired into the aftermarket approach lights along with the side vent lights so they come on when I unlock the car. they also stay on for 30 seconds after I shut it down. they do not come on with the parking lights, but there's a manual switch to turn them on. they are also wired into my strobe lights so they strobe if the alarm goes off. took lots of diodes to make them do all that without interfering with anything else!
I also have a custom built switch panel where one of the power outlets used to be. its got RCA audio inputs, USB for music, seat heater controls, manual light switches, and a switch to enable/disable the 4 on at once headlight mod.
here's a closeup
the led hvac controls look amazing. i wish i had the money to get that done, or the brains to do it myself
I relocated my coils to inside the fenders. I replaced the OEM intake with a ported FAST 92, I replaced the fuel rails with a pair from Nasty Performance. I have a custom fuel delivery system, using the RSI Dual Fuel pumps, custom -AN6 fuel lines all the way to the fuel rails, Custom fuel pressure regulator, ARP header studs, American Racing 1-7/8" headers, ProCharger P1SC1, custom propeller shaft, scattershield bell housing, RPM Stage VI+ 4L65E transmission, RPM Level 3 3.42 diff with 3-rib case. Pfadt motor mounts, diff brace, sway bars and coil-overs. Custom valve covers, ALKYControls methanol injection, Lingenfelter 90MM Throttle Body, SNL 90MM MAF, all stainless steel braided water hoses and fuel hoses, two black-chrome catch cans.
Here's a **** I made for mine. I do CNC work. I might could do a couple of these shifter plates, and i could put pretty much anything you want in them.
Well Mike, you've seen my car in person, but I'll add it to thte thread anyway. I feel that I have a unique vert.. has the sweet steet roadster look with the rollbar... but inside you see the 6pt welded bar, race seats, harness, and you cant see too well in this pic but also a black double din console that matches the waterfall and exterior paint. Also kinda unique is the molded front canards.. All the other cool stuff I have is hidden.
Bro, I so love your car. Very sweet and awesome mods. Going to Calabogie?
