[Z06] Heads?
Old Aug 7, 2009 | 10:01 AM
H82BU's Avatar
H82BU
Default Heads?
I have to do some clutch work this winter and fix the leaking dif so I think I may do everything I can over the winter and am tossing around the idea of head work. I have the G5x3 cam currently, would it be worth porting and polishing the heads or go with different heads? I don't want to spend $1000 dollars here.
Old Aug 14, 2009 | 12:36 PM
H82BU's Avatar
H82BU
no thoughts?
Old Aug 14, 2009 | 01:11 PM
Mitchell SWZ06's Avatar
Mitchell SWZ06
Truthfully if you don't want to spend more than a grand it's really not worth it, how many miles on the valve springs? maybe do a fresh set, and upgrade your rockers.
but to take advantage of the heads you have you are looking at spending 1k to 1500, and a new set your looking at 2k +, and yes there are budget heads out there, but remember you pay for what you get!
Old Aug 14, 2009 | 01:23 PM
ysb02's Avatar
ysb02
Sending them off to be cnc ported & polished would be the best hp gain per $$$. I don't think you can touch aftermarket heads for less than $2k.
Old Aug 14, 2009 | 01:34 PM
AU N EGL's Avatar
AU N EGL
for max of $1000 is it even worth taking the heads off? no I dont think so.
Save up some for some great heads with valves springs, new timing chain and a great tune
Old Aug 14, 2009 | 10:10 PM
BADZOH6's Avatar
BADZOH6
You can get a great head for under 2k. Trick Flow as cast heads are great heads for the money. Shoot Ron over at vengeance racing an e-mail (Ron@VengeanceRD.com) and he will take care of you.
Old Aug 14, 2009 | 11:18 PM
The Evil Genius's Avatar
The Evil Genius
From: Dayton, OH HAWG: "this is Off Topic...it can get a bit north of care bears and strawberry shortcake in here"
That's an expensive night in the red light district, eh?
Aside from that, save up some more scratch and make it worth it.
To Heads?
