Unique Problem With My C5
Old Aug 14, 2009 | 07:33 AM
CorvetteOJ's Avatar
CorvetteOJ
Default Unique Problem With My C5
I have never seen nor heard of this situation before. Normally, you can open your door and immediately see in the DIC, "Door Ajar." As of yesterday, mine does not, it remains blank until I insert the key and turn it all the way to the "ON" position. Nothing comes in the DIC window at the "Accessories" position. The only mods I have done recently is install the CLB bypass and the "Hyper Flasher FIX harness. Are there any ideas what may have caused this to happen. At the "ON' position everything is normal in the "DIC." Thanks for reading and would appreciate your response.
Old Aug 14, 2009 | 09:45 AM
dougbfresh's Avatar
dougbfresh
I think mine works the same. What's the big deal, you don't know the door is open? If you think it's one of the 2 things you did to it, remove them 1 at a tiime and fiind out!
Old Aug 14, 2009 | 10:09 AM
JCamaro's Avatar
JCamaro
Do they still use that little plunger near the door hinge...maybe yours is stick in the closed position.
Old Aug 14, 2009 | 10:39 AM
CorvetteOJ's Avatar
CorvetteOJ
Originally Posted by dougbfresh
I think mine works the same. What's the big deal, you don't know the door is open? If you think it's one of the 2 things you did to it, remove them 1 at a time and find out!
Doug I appreciate your response. First it is a big deal because it is not right and there is no obvious reason for it. As for disconnecting the wiring harnesses one at a time, I definitely thought of that but it can't be either of those because everything else works right when you open the door, ie., the instrument cluster lights up. Another thought, over 66 people have read this post and only two responded. I figure if 64 people did not respond they either have no clue or have never experienced the same issue. I am also guessing that a good percent of the none responders have also installed the two aforementioned wiring harnesses and never experienced the same issue or they certainly would have responded. Based on that assumption, I am doubly convinced it has nothing to do with either harness. Thanks for taking the time to post to this thread because you at least made me think through the problem logically.
Old Aug 14, 2009 | 10:44 AM
CorvetteOJ's Avatar
CorvetteOJ
Thanks for your response but it is not the door actuated switch because the instrument cluster lights up when you open the door. I realize I did not make that clear in my original post. If nothing happened when you opened the door then the switch would be my first go to point. Thanks again, I do appreciate you taking the time to acknowledge my concern.
Old Aug 14, 2009 | 11:25 AM
itzza427's Avatar
itzza427
Well this got my attention,,and had to make a trip out to the car and see just what it does!Now I don't know if there is a difference between models and years(mine is a 2000 FRC) but on mine the DIC did not activate till the key was turned to the "RUN" position. Now I do have to add that for right now I'm having an ABS/TC/Active Handling code problem,,,and the warnings DO repeat when I shut it off and remove the key. It will cycle through the warnings then go dark. Don't recall ever seeing anything till the key was on. I do know that there are several different setting choices that are available with the "OPTIONS " button.If your items are fairly new installations(did you do them yourself?) something may have changed with that button.This could have happened if someone else did the install. I do have a CLB,,but not the hyper flash piece(no LEDs). Just a thought!
Old Aug 14, 2009 | 11:45 AM
dougbfresh's Avatar
dougbfresh
Well, since your doubly sure (200%????) Are you sure (100%) it used to work that way? Mine does not till the key is ON. Doubt most people even notice the door ajar message till the car is running.
Old Aug 14, 2009 | 11:52 AM
bucwheat's Avatar
bucwheat
Gene,my DIC has never read anything until I put the key in,maybe it didn't have that feature in 98 I don't know,that would concern me also,unless there is a way to program that feature in.
Old Aug 14, 2009 | 12:06 PM
CODE4LS1's Avatar
CODE4LS1
My 98 does not read out "DOOR AJAR" unless the ignition is turned to the "ON" position.
Old Aug 14, 2009 | 02:04 PM
cdkcorvette7's Avatar
cdkcorvette7
My DIC doesn't read door ajar until the key is in.... 2001 6MT Coupe
Old Aug 14, 2009 | 02:11 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
obviously if you are 200% that is used to work regardless of the key position, the easiest way to isolate the problem is to reverse the 2 mods you recently made. then see if you are correct about seeing the display with the key out of the ignition (i doubt you will, but you never know). if you get the desired results, replace each of the "mods" one by one and check to see the results.
personally, i believe the door ajar indicator is active only when the car is "on" so that you can be alerted to a potential problem. parked in your garage with the engine off shouldn't present a potential problem in my opinion unless you are drunk and about to fall out of the car. i suggest however at that point you aren't looking at the DIC nor do you care, lol!
Old Aug 14, 2009 | 03:07 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I just went out to my '98 and checked and found that when I opened the door the IP Cluster displayed a flashing "SECURITY" light but the DIC was blank. When I turned the key to the "ON" position it displayed the welcome message and the "DOOR AJAR". I did this six times so I would be 600% sure.
If your DIC was displaying the "DOOR AJAR" message without the key in the ignition and turned to the "ON" position what you have actually done is to have repaired your car. Congrats!!!!
Old Aug 14, 2009 | 03:18 PM
GS Ron's Avatar
GS Ron
Me, also
Old Aug 14, 2009 | 03:31 PM
02MillenniumVette's Avatar
02MillenniumVette
I checked mine when I went out today and with the key not in the ignition, only thing I get is the security light and thats all. If the key is in the ignition and turned to "on" then I will get the "door ajar" message.
Old Aug 14, 2009 | 06:44 PM
dougbfresh's Avatar
dougbfresh
OK, I think I'm 800% sure now that the Door Ajar message never came on without the key in the RUN position. I just checked mine again.
Old Aug 14, 2009 | 08:28 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Well, I'm 100% sure that the "door ajar" message only comes when the ignition is set to "ON" in MY '98 (and I had to check only once). I do have the CLB and flasher bypass.
Well, there's a third option called, "Why don't I read this thread despite the nebulous title to see if there's anything I can contribute?"
Given that most didn't respond is indicative that you indeed had a "unique problem".
With your DIC, that is.
You appear to be healthy now.
Old Aug 14, 2009 | 08:32 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Maybe the OP has a problem with his ignition switch...set of contacts not doing what they were supposed to be? I don't remember my '99 ever saying door ajar either unless the key was in the ignition.
To Unique Problem With My C5
Old Aug 14, 2009 | 08:58 PM
dougbfresh's Avatar
dougbfresh
I think the OP never had a problem with his car to begin with!
Old Aug 15, 2009 | 08:01 AM
CorvetteOJ's Avatar
CorvetteOJ
Well guys, you did have me second guessing myself just a little. As a matter of fact, for a few seconds I thought it might have been another one of those proverbial "senior moments." However, I remembered that one of the things I always did to see my odometer reading was open the door, get the "Door Ajar" message, close the door and in a few seconds I would get the odometer reading to show for a few seconds, all of this with the key in my pocket and never getting in the car . I can not do that anymore. Based on everyone's input I certainly must have had a "unique ability" with my DIC which I no longer have. I have owned this car since December 2002 and I am very familiar with everyone of its characteristics. However, you guys have pretty much convinced me that whatever allowed me to do it for all these years must not have been the norm. I do appreciate your time although some of you seemed to be losing your patience simply because you did not believe me or could not relate to my "abnormal DIC reading. Trust me, I did have it before, but since you guys evidently don't and never did, then I am not going to worry about it. If anyone ever hears of this on another Vette, I would love to hear about it.
Old Aug 15, 2009 | 08:22 AM
dougbfresh's Avatar
dougbfresh
None of my other GM's work this way or the Ford truck-door ajar with the key out makes no sense. If you think it works, remove the stuff you added and see.
