Keyless Entry Problem
Old Sep 20, 2009 | 04:27 PM
Larrys60's Avatar
Larrys60
Default Keyless Entry Problem
2002 C5.Passenger side will not lock or unlock with key fob. It was only unlocking so I locked and unlocked it manually a few times, now it does neither. Manually it works ok and drivers side will lock and unlock with fob.
I can hear the solenoid click when pushing lock or unlock on the fob or the door itself?
Any Ideas?
Old Sep 20, 2009 | 04:29 PM
DeeGee's Avatar
DeeGee
Its the door lock module. The relaays are cheap and its a common issue. You can change the relay by breaking down the module or do a module change. I had one replaced under warranty but its going bad again
Take a look at Bakersfield's thread and you'll find all you need to know.
http://forums.corvetteforum.com/c5-g...w-problem.html
