Active handling comes on for no reason
Old Sep 23, 2009 | 07:48 AM
mikerino's Avatar
mikerino
Default Active handling comes on for no reason
Hi, tried a search and nothing came up. For the last couple of days active handling has come on while driving at 60 - 70 MPH flat dry road. It seems to be hitting the brakes on the passenger side rear wheel and seems kind of dangerous. Does anyone know what causes this and how I can troubleshoot it?
Thanks.
Old Sep 23, 2009 | 07:58 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Have you changed tires/ wheels lately?
Old Sep 23, 2009 | 08:17 AM
AU N EGL's Avatar
AU N EGL
What Year? 04?
a few 2004 had yaw sensor problems and a TSB put out.
robsc501's Avatar
robsc501
Hi There:
Check the simple things first. Is your air bridge coupling loose? Are your tires balanced? What codes are being displayed on the DIC? Dealer would have to check the yaw sensor. Possibly a bad yaw sensor if going in a straight line & at highway speeds & the brakes are being applied & the a/handing message is displayed.
robsc501
Old Sep 23, 2009 | 10:42 AM
mschamberger's Avatar
mschamberger
I had the same issue. Mine turned out to be a steering position sensor. The tech said the most common cause is the wheel speed sensor, SPS is the second most likely candidate.
Old Sep 23, 2009 | 12:57 PM
Bluefire's Avatar
Bluefire
Mine was the Steering Wheel Position Sensor. Eventually, I started to get the P1287 code with it. It's pretty scary driving down the freeway at 65 mph and the "system" decides to "tap" one of the front brakes.
I hope you figure it out soon.
Old Sep 23, 2009 | 04:33 PM
Cosmic Charlie's Avatar
Cosmic Charlie
UGH !!!!!!!!!!!!!!!!!!
Old Sep 24, 2009 | 10:59 AM
mikerino's Avatar
mikerino
Thanks for all of the answers. It is an 01, I have not changed the tires. Robsc501, what is the air bridge coupling? And I'm not getting any codes.
Can anyone recommend a place in southern NH to look at it? We have a big dealership in Nashua, MacMulkin but I am not impressed by their service department from many non-vett's I have brought there.
Old Sep 24, 2009 | 12:19 PM
C5jarhead's Avatar
C5jarhead
I know folks who swear by MacMulkin for their 'Vettes, and there's are worth alot more than mine.
I haven't needed service yet, so I can't speak first hand.
They are a sponsor here on the Forum, and typically get good reviews.
Good Luck!!
Old Sep 24, 2009 | 12:39 PM
Bluefire's Avatar
Bluefire
The dealership should be able to connect to a Tech II scanner and test the SWPS. It tests for: Power (+5V), GND. It also looks for linear voltage sweeps (0 - 5V) from both of the sensor outputs (A & B) that are 90 degrees out of phase to each other.
Old Sep 24, 2009 | 09:34 PM
robsc501's Avatar
robsc501
Hi There:
The air bridge has a big clamp around it.About 3 1/2" in diameter The rubber is shaped like a accordian. Take a common s/driver & make sure its tight.
robsc501
Old Sep 24, 2009 | 11:28 PM
corvettemods1's Avatar
0corvettemods1
Former Vendor
St. Jude Donor '12-'13
could be the yaw sensor??
Old Sep 24, 2009 | 11:31 PM
DeeGee's Avatar
DeeGee
With no codes I'd start with the simple things first.
Are your tire pressures even? A low pressure at one corner will affect AH
Pull the connectors at the wheel hubs and clean them up. A false voltage at one hub will cause a trip.
It could be so many things. Without codes you'd be changing things on spec.
Old Sep 25, 2009 | 04:12 AM
Jistari's Avatar
Jistari
Originally Posted by robsc501
Hi There:
robsc501
Just give me a two second explanation on how this figures into AH?
Much appreciated.
Old Sep 26, 2009 | 07:04 AM
robsc501's Avatar
robsc501
Hi There:
Thanks for correcting me. I goofed.Meant to say that when a/h is engaged that it sends a signal to the throttle plate to partially close the t/ plate thus reducing the power.
robsc501
Old Sep 26, 2009 | 10:18 AM
Mike Mercury's Avatar
Mike Mercury
Hi There:
robsc501
it does? never heard that before.
I've understood that Traction Control does that, btu this is the first time I've heard of AH doing it.
interesting.
To Active handling comes on for no reason
