IPod connection unit
Old Sep 25, 2009 | 01:22 PM
bluerose's Avatar
bluerose
Default IPod connection unit
I'm finally getting to buy a few things for my 2003!
One of the things I'm looking at is adding an iPod hookup.
I see there are 2 different brands offered. Is there a difference?
AUX2CAR vs Peripheral
Old Sep 25, 2009 | 01:51 PM
Aerovette's Avatar
Aerovette
PAC made the one I have in my Silverado and I am happy with it.
Old Sep 25, 2009 | 01:58 PM
Vega$Vette's Avatar
Vega$Vette
Peripheral
Old Sep 25, 2009 | 02:06 PM
miltievette's Avatar
miltievette
Peripheral thats what I run, do you have a CD changer in your trunk?
make sure you get the correct harness
Enjoy
Old Sep 25, 2009 | 02:50 PM
bluerose's Avatar
bluerose
Enjoy
No CD changer...so I need to get the one for doing it without.
Old Sep 25, 2009 | 03:03 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Hummmm. In installed the Ipod2car connector and their wiring harness that they recommend. Besure to check out all the connectors you will need with the configuration you will be running. THe Ipod2car set up was very quick and easy.
rr
Old Sep 25, 2009 | 03:17 PM
miltievette
Periphera with this you will need PHXGM 4 is sold separately for $15
EZ install I put mine in the center consul. All controls are on the radio
Old Sep 25, 2009 | 05:28 PM
esh3323's Avatar
esh3323
Default where to buy?
where do you all get the peripheal thingy and are they hard to hook up and cost?
Old Sep 25, 2009 | 05:41 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Do a search for "Ipod". Cozmo is the resident expert and has been a big help with the install process. All the info you need is there including instructions on how to access your radio. Took me about 45 minutes from start to finish. I am a slow worker and needed a cup of coffee along the way. Good luck!
Old Sep 25, 2009 | 06:04 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
I purchased from EBAY. The install was easy cause I followed Toque's directions. Best of luck! This is a great mod!
Old Sep 25, 2009 | 06:43 PM
bluerose's Avatar
bluerose
Thanks guys guess I'll go with the Peripheral. Looks like i can get all the parts for about 120 to 130.
Been on the fence with the iPod verses just getting and AUX 3.5 stereo connection since I have a blackberry too but I like the thought putting it in the center console and using the radio to control it.
Bought a bunch of stuff today...trunk liner and a partition, Gas/dead pedals, and the window valet module.
Just need this and I was looking at the skid plate stiffeners. Then I'm broke for a little bit
Edit: I forgot I also bought and will be putting in the new head light gears this weekend too...tired of that grinding noise in the passenger side headlight...
Last edited by bluerose; Sep 25, 2009 at 06:50 PM. Reason: Just adding a little tidbit.
Old Sep 25, 2009 | 09:25 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I wrote a full procedure on the install with pics. Its on my web site.
http://mysite.verizon.net/res0aae8/webpage.html
Scroll down to my link at the bottom ---> C5 Corvette IPod Install:
Hope this helps.
Toque
To IPod connection unit
