Engine swap
Old Oct 8, 2009 | 04:19 PM
SeanME's Avatar
SeanME
Default Engine swap
will a LS2 or LS3 fit in a c-5 without any major modifications?
Old Oct 8, 2009 | 04:32 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Yes.
Old Oct 8, 2009 | 10:47 PM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Especially since LPE has the adapter box so you dont have to deal with the relucter wheel etc...
Brain
Old Oct 9, 2009 | 08:03 AM
It should - and if you do it, be sure to post up pics of the process.
Old Oct 9, 2009 | 10:41 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Brain
That is the easy way to do it
Old Oct 9, 2009 | 11:25 AM
SeanME's Avatar
SeanME
ls7?
Old Oct 9, 2009 | 11:55 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
ls7?
Would require a lot of work as it is a dry sump unless you bought an aftermarket wet-sump set-up.
Old Oct 11, 2009 | 02:36 AM
Big Jay E's Avatar
Big Jay E
Brain
I went to their site and couldn't find it.
Old Oct 11, 2009 | 07:10 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
http://www.lingenfelter.com/mm5/merc...gory_Code=C163
Old Oct 11, 2009 | 07:15 AM
AU N EGL's Avatar
AU N EGL
You may find the LS2 needs a bigger radiator. the LS3 DEFINITIVELY needs a bigger radiator. The LS3 also highly benefits from adding a dry sump, if your doing any kind or performance driving or racing.
To Engine swap
