Any way of getting specs on the ramps so that I can build?
Sean
Used 2 x 10 lumber, 3" deck screws, carpenters wood glue
Total cost $ 40.00
Tools required
circular saw, cordless drill, drill bits, ruler, level
The ramps are 60" long with 2 approach angles.
The first 24" of the ramp are set at a 9 degree angle to avoid scraping the front. the next 24" of ramp are set at a 15 degree angle and the last 12" are a flat box that the tire sits on and is 12" off ground and has a stopper so you dont roll off.
Total cost $ 40.00
Tools required
I used the same materials. I used the following design. I can't remember who had the design on this forum. I used 3/4 inch plywood over the 2x10s
