Harmonic balancer wobble
Old Jul 16, 2012 | 02:21 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Originally Posted by 65GGvert
I am in no way telling you not to replace it. This is merely an observation. Since I've read about this on the forum a couple of years ago, I've looked at several balancers on C5's and all of them wobble "just a little" as you say. Enough to be noticeable if you're looking at it, but not enough to cause a problem.
I've noticed it as well. Never seen one that didn't have a little wobble to it.
Old Jul 16, 2012 | 02:45 PM
Lloyd Christmas's Avatar
Lloyd Christmas
Originally Posted by Z06 4 Me
How do you hold the engine from turning while torquing to 300lbs?
Try putting it in gear.
Old Jul 16, 2012 | 02:47 PM
Lloyd Christmas
Its hard for me to justify a $5-600 balancer for an engine that is internally balanced. I know, there are differences between physical balancing and harmonic dampening. I want to protect my engine, but when mine goes bad I will probably put a new stock balancer back on.
Old Jul 16, 2012 | 02:54 PM
KillSwitchNY's Avatar
KillSwitchNY
my fathers 80k miles C6 Just had the balancer bolt back out. He never would have known if the belts hadn't started squealing. I am ordering him an ATI balancer and ARP bolt asap. That should solve it. As fo the loosening the subframe bolts that sounds like a great idea if it indeed works.
Old Jul 16, 2012 | 07:38 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
This is a 2009 thread until today.
I still looked at it since my 99 FRC had one fail at 30k. I used a powerbond and replaced it myself. The steering rack was not much fun.
There are some good threads that detail how it is done and have pictures. They helped me a lot. I don't remember and didn't mark those threads, but if you look around some you can find a lot of info on this problem.
Old Jul 16, 2012 | 09:48 PM
Vette_DD's Avatar
Vette_DD
http://forums.corvetteforum.com/foru...s-or-more.html
