[Z06] Shedding Some Weight
2981 ! Thats excellant
care to post how you got to that weight ??
I still have to get to the Evaporator Core I think I am just going to wait till I need to go into the dash till I pull it out,
I still have to pull both airbags and need a cool set of headlights to replace the pop-ups,I've already lost the airconditioning and and condenser windshield wiper wash and pump ,
I also lost the very Fatt A/C delco Battery approx 35lbs ! and in it's place I added a Deka battery 20lbs to which I added a mini solar charger that links up via the cigerette lighter and keeps the Battery around 12.8 volts, there is an 11.5lb version of this batterie but I think I will opt for the higher 18Ah 15lb version I have 26Ah now and it's working great! soon I'll be pulling the airpump and associated plumbing,
In about 3 weeks I will be adding a header system that will futher lighten the car 20lbs via loss of the cast iron manifolds, I added the two tip cat back verses the four tip. I took out the reverse light panel and fabbed up a panel to match my car I will add L.E.D's to the vented lower rear facia when I find the one's I like
Next I want to loose the coolant overflow tank , Thanks to the guy that suggested adding a bottle in it's place,as well as the guy that suggested lightening up the front Bose to speakers without an amp,
working on locating the pipe to fab up a ti X-pipe mid section for the exhaust
Mockup still have to loose the crome frame and 4 bolts too much reflection in this picture
Bon
You might look at replacing the rear rotors with a front rotor. I haven't done it yet myself but I have seen a couple posts of guys who got rid of the heavy rear rotors (with integrated parking brake drum) and used a front rotor with a "puck size" caliper for the parking brake. The guys I saw used a C6 front rotor but a C5 front rotor should work fine.
I must be missing something here. Last time I changed rotors the fronts were significantly larger and heavier than the rear. Not sure how putting a larger heavier rotor on the back helps, in fact pretty sure you'd have to change more than just the rotor.
My car is currently getting a dry-sumped 427 and the AC is getting ditched to accommodate the dry-sump pump, as well as shed a few lbs.
I'm also interested in where the "low hanging fruit" for weight loss is (other than the driver, cuz I know where I can shed a few
). The airbags and stereo are staying in for now, it's still a street car for probably another 1-2 years. -TJ
lg pro headers and x pipe w/cats probably saved a few lbs.vararam prob.same as stock air filter setup.mabye cartek ported alot of weight out of the heads.(just kidding)
A lot of people seem to think this is a drag car, not a sports car. HP dosen't help cornering or braking. I'm not ready to pull airbags or carpet, but a lighter battery or carbon hood appeal to me. I recently read about light weight lug nuts. A little pricey to me, but it is unsprung rotational mass.
Good question about reverse lights if you look back in the posts,
I mentioned that I will be adding LED lights not only very bright, but also very small and light
I mostly eliminated the reverse lights because I think they are way oversize and don't really fit the car well
my rear panel is not done yet I am going to eliminate the crome lic plate frame and re-mount a black plastic or carbon frame, also the screws will disappear and I've already glued the panel to a piece of 1/8" gator or foam board as most people know it
Thanks, For All The Adds Everyone !
Bonne
Bonne
