Tire Flat Spots
Old Nov 18, 2009 | 04:28 PM
lp2004z06's Avatar
lp2004z06
Default Tire Flat Spots
OK, maybe a dumb question. I have brand new Goodyear OEM tires on my '04 Z06 and was wondering if I let it sits for months in my garage over the winter, will the tires get flat spots? Does this ruin the tire? Any product out there to help with this problem
Old Nov 18, 2009 | 05:12 PM
BanditDude's Avatar
BanditDude
Radial tires do not develop flat spots, per-se. Tthey may occur to some small degree, but will go away after driving a few miles.
Old Nov 18, 2009 | 06:16 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Yes flat spots can occur IF left for a very long period of time due to loss of air. As told to me by a professional who is also a friend, take for pieces of styrofoam that are wide enough and long enough that your car sits on them. The styrofoam takes pressure off of the tires and acts as a cussion.
Old Nov 18, 2009 | 06:43 PM
steve8's Avatar
steve8
Recent thread. Happy reading.
http://forums.corvetteforum.com/c5-g...-spotting.html
Old Nov 18, 2009 | 06:50 PM
dbaker's Avatar
dbaker
It's not so much the pressure on the tires,it's the change of temp of the contact surface that can make a temp flat spot on the tires.
My Z sits out on concrete all year,but I have some rubber mats I have the car sit on to help counteract the effects of the temp change.Seems to work ok.
\db2
Carolina
Old Nov 18, 2009 | 11:30 PM
O4-/-C5's Avatar
O4-/-C5
Pump your tires up to 40 psi during storage. Don't forget to drop back to 30 psi when you start driving again.
Old Nov 18, 2009 | 11:37 PM
The tires will be just fine. You may have a little bumpiness when you drive the car again, but within a couple of miles it should be smooth sailing.
Old Nov 19, 2009 | 12:38 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Make some extruded styrofoam pads for the car to sit on. Get the blue foam from Home Depot it works great I have been using mine for 7 years now. I think I'll make some new ones for next year thought. I cut two with bevels front and rear so I could drive over them then onto the front ones that only have one end beveled.
Old Nov 19, 2009 | 01:35 AM
DeeGee's Avatar
DeeGee
The precautions that the guys have suggested can't hurt but my experience is that any flat spots work themselves out inside a few miles.
My car used to sit for a month at a time in Vegas without issue. It also sat on a boat to England for 8 weeks. It wasn't even noticeable when I drove away from the Port. I had Michelin AS ZPs on by then which are slightly softer tires. The OEMs with harder sidewalls should stand up even better.
If you're worried just roll it a few inches in the garage every few weeks.
You'll be fine.
Old Nov 19, 2009 | 11:04 AM
03BlackClassic's Avatar
03BlackClassic
The design of a radial tire, will not allow the tire to permanently become flat spotted. The only reason for the feeling of having a flat spot once you get in a car that has been sitting for an extended period of time is because the tire looses air over time allowing the sidewall of the tire to sag. This in turn gives the allusion of having a flat spot. A radial tire is designed for this to not damage the construction of the tire, however if you were to drive the tire with out re-airing it up this can cause damage. If you are going to store your car for an extended period of time just be sure to check your pressure before driving on them.
To Tire Flat Spots
