Trouble removing EBCM Module
Old Nov 27, 2009 | 07:55 PM
leowiz's Avatar
leowiz
Default Trouble removing EBCM Module
So I removed the six T-20 torx screws but I am not able to take the EBCM apart. It seems its stuck together pretty nice. Am I missing something more or is there a particular way to pull it apart ?
Any ideas?
Thanks.
Old Nov 27, 2009 | 09:37 PM
giwhop's Avatar
giwhop
Had the same problem had to pry off with flat screwdriver.
Old Nov 27, 2009 | 09:47 PM
gregm999's Avatar
gregm999
Insert a flat head screwdriver a very small amount between where the ebcm meets the bpmv at the top. Once inserted, turn the screw driver about 90 degrees in a way that pries the ebcm away from the bpmv. Do this at several points on the top seal. Then use two hands to pull the ebcm toward the passenger side of the car, away from the BPMV. This method worked for me. Be sure not to insert the screwdriver too much or you might damage the seal.
Old Nov 27, 2009 | 09:51 PM
Dave68's Avatar
Dave68
Full procedure:
http://www.conceptualpolymer.com/Ele...l%20Module.pdf
Old Nov 27, 2009 | 10:37 PM
cdkcorvette7's Avatar
cdkcorvette7
Old Dec 7, 2009 | 05:49 PM
leowiz's Avatar
leowiz
Thanks all for the suggestion. It is out now and ready to be shipped to auto ECU place for rebuild.
Fingers crossed.
Old Dec 7, 2009 | 06:06 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Let us know how it turns out
Thanks,Matt
Old Dec 8, 2009 | 10:53 AM
Thanks for the good information.
Old Dec 9, 2009 | 12:31 AM
itzza427's Avatar
itzza427
Thanks for the info,,,bookmarking this and the guide!! Might have to give this a try,,mine is on the fritz right now,,and the budget is kind of thin!!
To Trouble removing EBCM Module
