Transmission additive?
Old Dec 8, 2009 | 04:23 PM
Tombone's Avatar
Tombone
Default Transmission additive?
I have a 1999 C5 6 speed manual.
The car has approximately 60000 miles.
At 40000 I changed the transmission fluid with Red Line D4 Automatic / Manual synthetic oil.
I think the car could shift with less effort with an additive.
Let me know if you can recommend a product.
Thanks.
Old Dec 8, 2009 | 05:17 PM
Cybermind's Avatar
Cybermind
Additives are not needed nor recommended in our trannys. I would simply try a different transmission fluid. I know that when I changed my tranny fluid to Mobil synthetic ATF, it greatly improved shifting. However, I think that you can't use synthetic fluid in '99's.
Old Dec 8, 2009 | 05:25 PM
leeinmemphis's Avatar
leeinmemphis
I just picked up my '02 M6 and had Royal Purple put in it. It makes shifting much easier than whatever was in it. I had to order it from Summitracing because I couldn't find it locally. I could find the engine/diff oil but the manual transmission fluid that RP recommended wasn't stocked anywhere locally.
Old Dec 8, 2009 | 05:32 PM
killain's Avatar
killain
Oldtimer
I have heard of this issue about ten times and almost all of the stiffness and balky shifting was gone after draining and refill with Royal Purple ATF !
Old Dec 8, 2009 | 05:38 PM
leeinmemphis
The people at RP recommended Synchromax not atf so that is what I used. They were very helpful in helping me locate the quantities I needed and helped answer a couple of suggestions. Not very often I encounter that level of customer service.
http://www.royalpurple.com/manual-tr...ion-fluid.html
Old Dec 8, 2009 | 07:34 PM
dobewillie's Avatar
dobewillie
Good link Lee thanks
Old Dec 8, 2009 | 08:05 PM
johnson-rod's Avatar
johnson-rod
Amsoil is OK for the early transmissions. I've had it in mine for the last year or so. Its a MAJOR improvement. Much more than you would think from a simple trans fluid change.
To Transmission additive?
