oil change
Old Dec 10, 2009 | 09:35 AM
ragtops's Avatar
ragtops
2nd Gear
Default oil change
If I'm using a moble 1 synthetic oil do I have to change the oil every 3000 or can it be change every 5000. Do the vettes run the oil harder than other cars.
Old Dec 10, 2009 | 09:38 AM
Gideon's_Test's Avatar
Gideon's_Test
If you are using Mobil 1 (factory fill), change the oil when the oil life monitor reads less than 10% (even this is conservative). For me, this is around 7,500 miles...
Old Dec 10, 2009 | 10:03 AM
DeeGee's Avatar
DeeGee
E-T who was involved in the design of the car posted a great summary of the oil life monitoring system. It really is avery clever system and took years to develop. Seems a shame to ignore it IMHO. I've copied the explanation below.
FWIW, I normally hit 1 year before 0% nowadays. When the car was a DD I'd get up to 10k from my oil
In short, its your car and many feel happier doing old school oil changes. With synthetic oil and the OLM system it really is a waste of $$$. HTH
Oil Life Monitoring
Courtesy E-T
Here is how the OLM system works..
Mileage has little to do with how oil is monitored, here is the idea:
Car 1:
If you drive 90% of the time on the highway lets say 1500 rpm an hour.
you engine sees 90,000 revolutions in that hour and you drive 60 miles.
Car 2:
If you drive around town, profiling with 90% of your driving in 1st, 2nd, and 3rd gear, taking 4,000 rpm on average. That's 240,000 revolutions of the engine in 1 hour and you only drive 30 miles.
Taking this out to 3 months , 90 days:
Car#1 3,600,000 rpms and 5400 miles
Car#2 21,600,00 rpms and 2700 miles
This represents 1 hour of driving a day for 90 days.
Car #2 sees 6 times the engine duty of car #1 and Only half the mileage
So you can see that mileage can be very misleading. Considerations are: Starts, Cold starts, oil temp over time, rpm, mileage, engine coolant temp, load, knock sensor feed. Calculations are used to decrease the oil life percentage from the baseline.
Old Dec 10, 2009 | 10:23 AM
jrose7004's Avatar
jrose7004
I change oil every 10,000 miles or 1 year whichever is first.
Old Dec 10, 2009 | 11:38 AM
bucwheat's Avatar
bucwheat
I change mine when the monitor reaches 80%.
Old Dec 10, 2009 | 11:39 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oil Life Monitoring
Courtesy E-T
Car 1:
Car 2:
Great answer Dave!
Bottom line is with today's synthetic oils, it isn't neccessary to change oil every 3K miles.
Personally - I have three cars that all have OLM's, all three use synthetic oil as a factory fill, and all three use more than 6.5qts., so if I changed oil every three months or 3K like in the old days, I would be changing oil (expensive oil) all year long.
As Dave pointed out - a lot of engineering went in to making the OLM a valuable functional tool, instead of a gimmick. I follow the OLM, and I change my oil basically once a year.
BTW - I had a brief PM correspondence with E-T about a week ago, and for those interested, he's doing great.....and he is by his own admission, more mellow! I really miss having him around all of the time......
Old Dec 10, 2009 | 12:08 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Old Dec 10, 2009 | 02:16 PM
2KFRC5's Avatar
2KFRC5
Here's a GM Oil Change calculator.
http://www.gmols.com/index.htm
Click on Implementation Tools on the top bar.
Go down to Additional Tools.
Click on Engine Oil Life Predictor (.xls)
I put my stats in and it predicted 7561.38 miles from my last change to the next. I'll see how accurate it is a little later, according to the OLM.
Old Dec 10, 2009 | 02:31 PM
rdline's Avatar
rdline
yeap about 7500 miles unless car sitting for a long time during a yearly period
Old Dec 10, 2009 | 02:52 PM
Dave68's Avatar
Dave68
I never go longer than 1 year (as per our owner's manual), which for me represents about 5200 miles of driving.
thisMSGgood4me's Avatar
thisMSGgood4me
So what if the car sits for a long time, is that wearing out the oil? If a car sat idle for an entire year since its last oil change, would you change the oil again just because a year had passed?
Old Dec 10, 2009 | 02:54 PM
R Devil's Avatar
R Devil
Holy crap.
Old Dec 10, 2009 | 02:55 PM
thisMSGgood4me
What's magic about 1 year (other than that's what the owner's manual says)? What's your OLM down to after 5200 miles?
Old Dec 10, 2009 | 03:11 PM
hotwheels57's Avatar
hotwheels57
I'm going on a year and a half since the last oil/filter change. The oil life monitor says 80%. Our summer monsoon weather and now winter snow doesn't always allow me to get the car out every weekend. I'll change it next spring though.
I think the "one year" option was so owners just don't totally forget to do the oil/filter preventative maintenance. Most "enthusiasts" won't let that happen. Many "owners" (there is a difference) might. Hell, some don't even know how to find their DIC.
If in doubt, have the oil analyzed. Personally, I have a difficult time believing that oil is still good at 364 days, but not at 366 days.
Old Dec 10, 2009 | 03:27 PM
Hammer99's Avatar
Hammer99
I think the issue with it sitting long periods of time (unless it is in a temperature controlled environment) is condensation.
Someone correct me please if I am wrong.
Old Dec 10, 2009 | 03:57 PM
thisMSGgood4me
Condensation is not dependent on whether the oil is new or not. It's the environment which the car is in (as you pointed out).
Old Dec 10, 2009 | 04:02 PM
thisMSGgood4me
Exactly.
Conventional wisdom for what seemed like forever was 3000 miles or 1 year, whichever came first. Now the 3000 mile part of the equation has gone by the wayside, with advances in oil and engine technologies. So is the other part of that conventional wisdom also out-of-date? Something to think about.
To oil change
Old Dec 10, 2009 | 04:50 PM
Tom/99's Avatar
Tom/99
It's your car and your money, change the oil as you are comfortable with. That's what I do.
Old Dec 10, 2009 | 05:00 PM
srs244's Avatar
srs244
St. Jude Donor '09 thru '26
Originally Posted by 8VETTE7
Use the oil life monitor function unless you drive so few miles the oil would be in the car over a year. Then I would change it at least once per year. IMHO it's not a good idea to just let the contaminents that end up in the oil sit for more than a year.
Old Dec 10, 2009 | 05:17 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I do 2k on my C5 oh it is boosted and needs it, on our C6 after breakin I am doing it at 5k and the oil still has a little golden tint in it and this works for me
