Need Help Removing Computer
Old Dec 22, 2009 | 03:42 PM
nassaubluecoupe's Avatar
nassaubluecoupe
Default Need Help Removing Computer
Trying to get the computer out to send off for a tune. Removed the two side screws from the brackets and the two screws that mount the harnesses to the computer but can't get the computer to budge. Need some quick advice/help. Thanks in advance.
David
Old Dec 22, 2009 | 03:53 PM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
I just pulled mine out and had the same problem. Try tapping with a rubber hammer while pulling it straight out. You will probably see some fine dirt start falling while you are tapping on it. It should come out. Mines a nassau blue coupe also. Maybe it's the color.
Old Dec 22, 2009 | 04:00 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
I believe there is a 3rd screw that holds that "front" bracket on, that is located way on the aft side where you can hardly reach. Did you get that screw?
ALso, a lot of computers apparently get "stuck" to the back bracket. Some sort or corrosion or something seems to weld it pretty good. I actually broke my bracket while trying to get the computer out.
If that happens to you, be glad that the brackets are only $15-$20 at the dealer! I got a brand new bracket and life is good.
Old Dec 22, 2009 | 04:06 PM
nassaubluecoupe
Thanks, guys. I guess we'll just have to get rough with it. I'm just hope I don't break something loose in the computer.
Old Dec 22, 2009 | 04:10 PM
Alaskanpilot
Just hold the computer firmly, because IF you break the mounting bracket... the sudden lack of resistance means the computer is likely to fly out of your hands. Ask me how I know.
Old Dec 22, 2009 | 04:16 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Good tips! It was a PITA when I got mine out and sent to ECS, but well worth it.
Old Dec 22, 2009 | 04:29 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have a full write up on our web site, give me a bit and I'll link it for you.
Old Dec 22, 2009 | 04:31 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
C5 PCM Removal Instructions....
http://www.eastcoastsupercharging.co...5_corvette.pdf
Old Dec 22, 2009 | 06:01 PM
nassaubluecoupe
Thanks everyone. We got it to break loose without damage to anything.
To Need Help Removing Computer
