Do you manually change gears while driving?
Yes better acceleration.
I don't think you'd get much more noise, maybe a tad. 3.42's are stock in the 6 speed.
I've found some good, low mile used ones(complete rear differentials) on here for around 600 + shipping. Probably $4-600 for labor to swap it out.
I've found new ones for $12-1600.
If I'm at a light and I'm want to 'feel the power', I pull it down in 1 and shift manually. It's not quite as exhilarating as a 6 speed, but it does make it more fun.
Always pull it out of OD when you are gonna play. You don't want it to downshift out of OD under a lot of power.
exactly how i drive mine My a4 is the same way. 3 operates normal, at slow speed it will kick down from 3-1. In second tho', it stays in second.
A 3.42 final drive ratio in an A4 means that the gears you will get better acceleration and that in top gear (fourth) you will be turning at a higher RPM. This is a very common upgrade and a very satisfying change, giving better response. The fuel mileage and noise level penalties are almost insignificant compared to the better feel. It will really wake the car up!
Having the shift points and shift pressures altered through a "tune" gives more performance oriented experience to the A4. The 3.42 upgrade plus a sharp professional dyno tune will really enhance your A4.
I drove my A4 for many miles around CA and NV including a road trip around Tahoe.I have the same trouble as you. On the rural roads I find the car always wants to upshift. On the bends that's a pain and I don't feel in control. I normally drop a few gears to make sure it stays in the appropriate gear. If you do though, make sure you keep an eye on the gearbox temperatures. Overtemping the box is a bad thing!
I agree that the kickdown can be lethargic and unpredictable. Without active handling the car is not fun on the back roads unless you're totally on top of it and not slowed down by people "pottering around". But with European gas prices we need to keep a sensible head. $7 a gallon is not fun and I can adjust my spend instantly with my right foot
You can have the A4 recalibrated and those who have had the mod say it makes the car seem totally different. The tuner will change the shift points and make it more suitable to your style. It may reduce the life of the box though.
If you decide not to go that way, try dropping to 3 or even 2 on the back roads or whenever you want the performance.
I know how many mods you have made to comply with EU standards, so changing to an MN6, however desirable that might be, is not an option.
Autos have a lower first gear, a little higher 2nd, and 3rd gear is the same ratio as 4th in a manual. OD is almost the same as 5th in the manual. Check this out. Scroll down about half way.The a4 has a stock rear gear ratio of 2.73 or an optional 3.15. With 2.73's, the manual is a little quicker. 3.15's even that out a little. 3.42's in an auto should make it a bit quicker than the manual. If I figured right, it should run about 400 rpms higher at highway speeds.
I confirm the gear box will let you start in second if you are in position "2". It is usefull for example under very slipy conditions (ice ans snow). I am not sure it'll kickdown to "1" if you floor. Or maybe at very low speed?
My vette is a European model so I had no changes to do. But for sure I can't change the gear box.
I will do the autobox remap but on a conservative way. No boosting the pressure too high. I just want to avoid that tendency to always upshift and the very aggressive kickdown when not expected. I also want the gear to do 4-3-2-1 when i decelerate. Not 4-1 as it does not.
My feeling is that the car is perfect for large straight roAd like in the us. In our more "rural" roads and our different driving style we need a different gear management, more rigid swaybars and maybe different tires.
Then we have the perfect car for nice driving (on the good side of the road).
The C6 or the Z06 swaybars are fit form function replacements. That will stiffen up the ride.
I already fitted Michelin AS ZPs but they're not available here in Europe. Way better than the stock tyres. Vredesteins may be available but they're not runflats.
As for the "good" side of the road, I guess I'm in the minority here.............
Then I'll get a gearbox remap.
Then I'll change my intake for ls6 manifold + callaway honker + 2001-maf (to go with my borla stinger catback)
do you think it'll do well?
I wish my wife would let me do the same
You may want to invest in a Z06 plug kit in case you get a flat
I also read a qaife differential was a great addon.
And... This conversation about changing the gear ratio makes me wonder if it is the best investment : you keep a stock engine but dramaticaly improve perf. Maybe better than gaining 20-30 hp?
2:73 = 2,730 RPM's
3:15 = 3,150 RPM's
3:42 = 3,420 RPM's
Not sure about top end, but how ofter do you need to drive over 170MPH?
