From: Marlton. Increasing performance one speeding ticket at a time! NJ
Absolutely a waste of time.
For one, the computer can switch gears much better and faster than you.
Second, downshifting is only accomplished when the computer determines that parameters are appropriate. For example, if you're going 70 mph, and try to put it into 1st, it won't do anything. Will only shift when the RPM and MPH threasholds are met. So to get reliable (if that's the best word to describe it) shifts, a computer controlled auto is not the best thing to use. Plus since it's decoupled from the engine directly through a torque converter, you're never going to get the feel of a manual car.
Third, for anything but racing applications, brakes are more than fine for hard use.
Now, despite the computer controlling the transmission being bad for a "drivers" car, it is an absolute godsend for the average driver. You can't do something stupid like overrev, or put the car into reverse when going forward, etc. The protection routines are there to keep the equipment and yourself safe.
The transmission is definately a weak spot in an auto car for road racing. But for consistant operation (like 1/4 miles), it can't be beat.
Originally Posted by dlivewyer
I had a '99 chevy truck that would start off in second when held in second, and it would not kick down.
My a4 is the same way. 3 operates normal, at slow speed it will kick down from 3-1. In second tho', it stays in second.
Originally Posted by blacksedan87
Shifting an A4 manually simply locks out the higher gear, not the lower ones, except for second gear which will allow a second gear start. But if you floor it, it will still downshift to first. Conversely if you leave it in third, it will start in first and run through second and third, locking out fourth (OD). All of this information is in the owner's manual.
A 3.42 final drive ratio in an A4 means that the gears you will get better acceleration and that in top gear (fourth) you will be turning at a higher RPM. This is a very common upgrade and a very satisfying change, giving better response. The fuel mileage and noise level penalties are almost insignificant compared to the better feel. It will really wake the car up!
Having the shift points and shift pressures altered through a "tune" gives more performance oriented experience to the A4. The 3.42 upgrade plus a sharp professional dyno tune will really enhance your A4.
100% correct. It is done for traction, because a car starting in 2nd gear will have approx 57% of the torque delivered to the rear wheels than 1st gear. But when RPM and MPH parameters are met, it will still downshift into 1st.
Changing to 3.42 gears and a tune definately made a difference in mine. But remember, once you start the modding, you can't stop! I also now have headers, cat backs, and a supercharger. What's next????????????? Enjoy your Corvette.
I have a different opinion. Upgrade your gearing to at least 3:42's, install a performance converter and increase your line pressure on your A4. I used to do the shifting / downshifting to get the power thrill, however it is no longer necessary. tons of power to the wheels and firm, crisp shifts by the A4
Whar is a performance converter? What kind of advantage do you get from it?
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Here's a link to Torque Converters and how they work. A performance converter will multiply torque better than a stock converter. Lots of choices and they will give you a different feel than stock converters.
[QUOTE=DeeGee;1572607790]I should say at the outset, driving an A4 in the US and driving it in Europe is like chalk and cheese. Like you I drive European type roads here in UK although we drive on the "correct" side of the road I drove my A4 for many miles around CA and NV including a road trip around Tahoe.
DeeGee, dont believe that CA and NV roads are representative of driving everywhere in the States. Driving the switchbacks through the Smokie Mountains on the east coast is much more like driving through Europe than you may imagine. It is on these roads that I really enjoy my six speed manual gearbox.
I also like to go D to 3 to 2 when decelerating (saves brakes).
My question: do you do this? Is it bad for the gearbox?
Thanks.
Cedric
Brakes are less expensive to replace then a transmission.
for Street or public road use, just let the transmission do its own shifting
Now on a road race course, then YES you want to manually shift the automatic, down shift at the end of the brake zone, prior to going into the corner. Then upshift after the corner
I know just what you mean. I've driven maybe 30 of the States and I think I've seen scenery and conditions which remind me of most countries in Europe. I guess I mentioned CA and NV because that trip from Vegas to San Fransisco and back to Vegas down PCH took in probably 5 different types of driving. The shifter was a blur at times. I followed one guy dropping down into Tahoe who rode his brakes the whole descent. Its amazing he had any brakes left when he hit the bottom.
That said, most roads in the US make most roads in Europe seem tiny. The road through my neighborhood in Vegas was wider than the M1 which is our main highway.
I just get the impression that many on the Forum consider freeway driving to be representative. Anyone who drives in Europe knows that freeways, autobahns and motorways are not the norm. I still say that sometimes letting the transmission do its own thing is not the best way to drive. In Vegas it was D all the way. Around here I set the transmission how I need it.
Each to his own I guess
Agreed. I drive in the UK, France, Belgium, Italy, and Switzerland on business quite often and know that the roads are quite different and that what we here in the States take as the norm is not in Europe. I have noticed that you in the UK drive on the "wrong" side , that French drivers seem to think all others drive inferior (just kidding), the Swiss have very strict driving etiquette , the Belguim drivers are more interested in where the next beer is to be found, and that the Italians believe brakes should be optional on any auto purchased!
I think that one of the original concerns was: is the manual shifting of the A4 harmfull? I hope some trans experts chime in, but the A4 is related to the previous 4L60E. These auto's do not like to be downshifted repeatedly. After a while you will see the apparent engine braking fade away to nothing, which is what happened to my previous Camaro.
So, like some of the guys above said, "brakes are cheaper than transes". Be carefull!
The guy who will do my gearbox tune will increase the downshifting (will downshift at higher rpm): do you think it'll be very harmfull to the gearbox ?
So true. We actually chose the correct side of the road because the French drive on the right J/K But we should all respect the Germans. They use the fast lane for overtaking
