eckler's splash guards?
Old Jan 5, 2010 | 10:13 PM
RDnomorecobra's Avatar
RDnomorecobra
Default eckler's splash guards?
got these for Christmas ... seems like a goofy design. anyone using these? I'm just holding it in place here ... I emailed Ecklers and they said yes this is the correct part for a c5 and that's what it would look like mounted.
Old Jan 5, 2010 | 10:48 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Strange. The splash guards I have are just a flat piece of plastic. The cost was low and the look is nice. There are three dimentional ones like yours that do look better. I'm glad I stuck with the flat ones as the fronts scrape the ground on hard corners. I think if they were not flat, they would have been ripped off as they would not flex like the flat ones.
Old Jan 6, 2010 | 02:41 AM
dougbfresh's Avatar
dougbfresh
I've got em-work great. You might want to sand them to get them to fit PERFECT. In all honesty, you probably only need the front ones since the front wheels cause most of the paint damage.
Old Jan 6, 2010 | 03:01 AM
DeeGee's Avatar
DeeGee
Not seen those before. I adapted C6 fender guards
Old Jan 6, 2010 | 07:55 AM
dougbfresh's Avatar
dougbfresh
These guards have been around for years, most vendors have pics on their websites installed (Like MidAmerica).
Old Jan 6, 2010 | 01:28 PM
Cirrus8's Avatar
Cirrus8
Here are some pics of my splash guards. I got the set that was already painted to match my car. Installation is easy but you must be precise -- Measure twice and drill once!!!
Old Jan 6, 2010 | 01:35 PM
Cirrus8's Avatar
Cirrus8
Here are two more from the side so that you can see the molded fit.
Old Jan 6, 2010 | 08:18 PM
jrose7004's Avatar
jrose7004
Those really look pretty good.
Old Jan 6, 2010 | 09:53 PM
RDnomorecobra
I guess you can't see the inboard part of it unless you crouch down and look. Just seems strange to have that open part hanging out there (rightmost side of my pic in the OP). I'll get my son to hold it in place while I walk around from different angles. I want them more for function rather than form.
Old Jan 6, 2010 | 10:12 PM
ROJ#79's Avatar
ROJ#79
I bought a set from Eckler's 5 years ago and I love them.
They protect from stone chips.
Old Jan 7, 2010 | 01:15 PM
Torch Red 02's Avatar
Torch Red 02
I have the same ones in black. My wife and I put them on our 02 coupe last year. We measured MANY times before we drilled (and had to pull off the back wheels). We spent about 2 hours making sure we got them on right, and tight. But, in the end, it was worth it. They look great / like OEM. Good luck.
Old Jan 7, 2010 | 06:11 PM
Redneck Slim's Avatar
Redneck Slim
Active Streak: 90 Days
I prefer those flat ones that Eckler's sells. No drilling. I ordered mine direct from the maker and had them shortened 1" for no scraping (no extra charge). autoxtc.com and whispermotorsports.com
Old Jan 8, 2010 | 06:28 PM
Joe Babe's Avatar
Joe Babe
molded and painted are the best.got them from mid america...comes in colors as well
Old Jan 8, 2010 | 07:17 PM
ENJ's Avatar
ENJ
Yes they do look funky, but they seems to prevent small rock chips from occuring on the panels behind them. All that I noticed from the rear wheel area is that the exhaust mufflers gets dirty more than normal. I like them for my car.
Old Jan 8, 2010 | 07:20 PM
LMFD296's Avatar
LMFD296
have any pics of that?
Old Jan 9, 2010 | 04:56 AM
PSU 98's Avatar
PSU 98
Just searched and found it myself:
http://www.nitekrazze.com/images/Corvette/C6Fender/
Old Jan 9, 2010 | 08:19 PM
O4-/-C5's Avatar
O4-/-C5
Your fender guards look great! I have not seen an after market guard that I like yet.
Are there any C6 for the "front" that can be modified?
I am getting chips on the lower rocker panel (both sides) just below the door in front of the rear wheel well where the slight body flare is. I believe these chips are coming from road junk kicked up from the front tires.
To eckler's splash guards?
Old Jan 10, 2010 | 03:59 AM
PSU 98's Avatar
PSU 98
You can buy a whole set of C6 splash guards for around $100. That includes two for the front and two for the rear.
Old Jan 10, 2010 | 05:52 AM
dougbfresh's Avatar
dougbfresh
Where??? All the ones I've found are $100/wheel made for the C5 or about $70/wheel for the C6 ones you have to modify to fit correctly.
Old Jan 10, 2010 | 11:04 AM
O4-/-C5's Avatar
O4-/-C5
Who sells these and do they have a web site so I can see them?
