tire question
Old Jan 14, 2010 | 09:36 PM
Gitusum's Avatar
Gitusum
Default tire question
i am upgrading my rims to 18 fronts and 19 rears. my question is on the fronts will a 255X40X ZR18 tire be too tall and too narrow for a 18 x 8.5 rim? or should i run a 35? i will be running 35s in the rear. thanx in advance.
Rick
Old Jan 15, 2010 | 02:26 AM
dieseldave56's Avatar
dieseldave56
Default plug and play..........
Here, just plug in your OEM and compare to whatever you had in mind.http://www.rims-n-tires.com/rt_specs.jsp?postId=906
Old Jan 15, 2010 | 03:07 AM
TheDingo's Avatar
TheDingo
are you getting free tires or something? why would you run a 40 series tire in the front? If your car is lowered, judging by clearance on my car, it's probably going to rub the fender when you turn.
IMO you should go w/ a 35 series.. the 255 will go fine on the 8.5" wheel. also, maybe a 30 series in the rear.
what tires are we talking about? also, if you're 'upgrading' why not put a 9.5" wheel in the front?
Old Jan 15, 2010 | 07:43 AM
Gitusum's Avatar
Gitusum
i wish i was getting free tires!!! i am buying a set of house of wheels 18x8.5 and 19 x 10.5 rims in black and i will be running the bf goodrich g force ta kdw tires and i am getting the 285/35/19 for the rear and was looking to see what would be a good size for the front. and as of yet the car has not been lowered but may lower it on the stock bolts a 1/4 inch i think is what the car will go on stock bolts?
but i did find a great deal on a set of 255X40X ZR18 g force so thats why i asked this particular size
Old Jan 15, 2010 | 01:06 PM
TheDingo's Avatar
TheDingo
I think you can get more than a 1/4" out of the stock bolts. I'm not sure because I switched to coilovers before I had the chance to screw with it.
Getting back to your question, I would stick with the 35 series tire just to be safe and to save yourself a possible headache later.
Old Jan 15, 2010 | 02:02 PM
MG RED 99's Avatar
MG RED 99
Can you try for a 18x9.5 front rim. If so go with a 265 or 275 x 35 x 18series tire.
Old Jan 15, 2010 | 02:10 PM
Gitusum's Avatar
Gitusum
i dont think the vendor has this style wheel in 9.5 i dont think
Old Jan 15, 2010 | 04:08 PM
TheDingo's Avatar
TheDingo
Yep. If you're going to upgrade.. do it right. Do the 9.5 w/ a 275!
Old Jan 15, 2010 | 09:55 PM
redvette365's Avatar
redvette365
Just bought new C5 Z06 wheels in chrome from House of Wheels. 18x9.5 and 19x11. Will be putting Hankook Ventus V12's on them 275/35-18 and 305/30-19
I would definitely go with a wider wheel.
Old Jan 16, 2010 | 04:21 AM
dieseldave56
Default BFGoodrich..........
Last month picked up this set of 265/35-18 BFG KDW2 on 9.5X18 (57mm offset) and 295/35-19 BFG KDW2 on 10.5X19 (56mm) *Factory Reproduction wheels. They're fitting well under the 2000 FRC ( OEM ride height w/C6 Z06 shocks) but the rears are too tall for the '01 Z06. The best part was the mounted, balanced ,new lug nuts, no tax ,out the door price of $1150
Old Jan 16, 2010 | 11:51 AM
LisaJohn's Avatar
LisaJohn
St. Jude Donor '10
J says thanks for buying BFG tires! When we need new tires we will get BFG g force.
L
To tire question
