[Z06] Lightweight Battery Install
Jan 19, 2010 | 04:48 PM
I did something similar, but used a Deka battery. Same as the Odyssey, but 1/2 the cost. Been very happy with it.
Jan 19, 2010 | 07:54 PM
Quote:
Originally Posted by
clemsondave
...and where did you find the Deka battery?
Jan 19, 2010 | 08:36 PM
What technology is it, gel, etc? FYI there was a good battery article in the last Vette Mag I received.
Jan 20, 2010 | 09:54 AM
zulatr
I don't remember, but google will pull up several sites. I have the 10lb version: Deka ETX14
I rarely drive the vette so I have to keep it on a trickle charger. Of course, I have to do the same when I have my red top Optima in it.
Jan 20, 2010 | 10:09 AM
Good to know, these things have a long shelf life so i've been told so hopefully i'll get a few more years out of it before it needs replacing.
Looks like the Deka and the popular Braille batteries are the same just rebadged.
Jan 20, 2010 | 12:07 PM
Last C5
I didn't get to save quite as much weight using the Odyssey 925 but I've had it in there for over two years now without a problem. Great batteries.
where did you get the battery hold down/cover? or did you fab it yourself. it looks good
Jan 20, 2010 | 01:00 PM
Jan 20, 2010 | 01:28 PM
What do you think about running one of these lightweight batteries with an aftermarket stereo amp/sub? I called a shop on the Deka and Odyssey and they look up stock specs and say you 620 cca and these are rated at quite a bit less.
Jan 20, 2010 | 02:42 PM
I have this hold down if anyone is interested:
It fits Odyssey PC680 and PC545 hold down HD680 - HD545
Probably will work for some other brands too.
Jan 20, 2010 | 07:00 PM
MENDERLE
To be honest, adding all that extra weight with the amp, subs and boom box equipment, is pointless with a lightweight battery. Why save 20 lbs. on the battery but to gain another 50 lbs. in stereo equipment? Besides, all that amperage drain is probably better suited for a deep cycle type battery,a bigger one such as an Optima yellow top, and it costs less too.
Jan 20, 2010 | 07:33 PM
Warren GTS
It seems to me that it would make even more sense to want to save extra weight on the battery if you're adding more weight in stereo equipment.
Jan 20, 2010 | 07:41 PM
TheDingo
My point exactly battery reduction would be a good offset. Or more hp's.
Jan 20, 2010 | 08:03 PM
Stevo92z28
PM'd you
Jan 20, 2010 | 09:26 PM
Steve did you fab that hold down?
Jan 20, 2010 | 10:53 PM
Jan 21, 2010 | 01:49 AM
Warren GTS
What he said. The Z badge was laying around the shop and I thought it looked as good there as any place else.
Jan 23, 2010 | 03:47 PM
Just want to update. Car sat for 5 days and went out there this morning and she started right up. Mid 30s this morning.
Jan 23, 2010 | 04:32 PM
Jan 23, 2010 | 04:56 PM
how much do the red top 6 cells weigh? anybody know?
Jan 23, 2010 | 05:47 PM
33lbs it looks like on summit.
