[Z06] Lightweight Battery Install
Old Jan 16, 2010 | 05:15 PM
Stevo92z28's Avatar
Stevo92z28
Default Lightweight Battery Install
Good way to drop 21lbs off your front end when your battery goes out:
I used this with my 13:1 compression 355 sbc in my camaro which had no problems what so ever turning that over. Just installed it in the z06 and it is working great. Only 15lbs in weight and easy install. Just had to drill 2 - 5/16 holes in the battery tray and slide the j-hooks through. You can pick up a universal battery holder at most parts stores. I plan to trim the j-hooks so they are not so long. Battery is an Odyssey PC680. Just thought i'd share.
Old Jan 16, 2010 | 05:45 PM
TakeAwayTheFear's Avatar
TakeAwayTheFear
nice! I had one in my last car, and never had a problem with it either.
Old Jan 16, 2010 | 06:58 PM
ZO6ME's Avatar
ZO6ME
So the battery lays on it's side? I am in need of a new battery and have been looking into lighter ones.
Old Jan 16, 2010 | 07:02 PM
ZO6ME's Avatar
ZO6ME
Is this basically a motorcycle battery?
Old Jan 16, 2010 | 07:07 PM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
St. Jude Donor '16 thru '26
I have installed several Odyssey battery’s in special applications that needed a fast recovery after a severe discharge from running emergency equipment. They have held up very well, and solved a problem we had in our fleet.
Old Jan 16, 2010 | 07:55 PM
Stevo92z28's Avatar
Stevo92z28
Yes you can install them anyway you wish. They are basically a motorcycle battery. Hard to believe they could get the job done but they do and do it well.
Old Jan 16, 2010 | 09:53 PM
ZO6ME's Avatar
ZO6ME
Good info. I might just do this.
Old Jan 17, 2010 | 03:18 PM
Last C5's Avatar
Last C5
I didn't get to save quite as much weight using the Odyssey 925 but I've had it in there for over two years now without a problem. Great batteries.
Old Jan 18, 2010 | 09:54 AM
PA Z06's Avatar
PA Z06
pretty cool
Old Jan 18, 2010 | 01:20 PM
Warren GTS's Avatar
Warren GTS
I went with the larger Odyssey PC925 as well, had it over two years and still cranking strong.
Made in the USA
Old Jan 18, 2010 | 03:32 PM
TurboTnZ06's Avatar
TurboTnZ06
I always had trouble connecting the posts to the GM booted wires. What did you guys use to attach? I ran a 925 and the 680 in my Z06 for a while. Currently the 680 is in my drag car and a regular cheap Walmart special is in the Z06.
Old Jan 18, 2010 | 04:00 PM
Stevo92z28's Avatar
Stevo92z28
Had to purchase those brass side/top mount terminals. That and just added a washer to the inside so the bolt didn't bottom out.
Old Jan 19, 2010 | 01:13 AM
Warren GTS's Avatar
Warren GTS
I remember those cables being somewhat loose even though the bolt was threaded all the way, so I added a washer as well.
Old Jan 19, 2010 | 04:28 AM
TheDingo's Avatar
TheDingo
I'd like to hammer one in to my roof and run the lines down in to the car with an attachment to my nipples then route them out to under the hood.
4:28AM
Old Jan 19, 2010 | 12:01 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Steve,
Looks good.
Where did you get it? and how much?
Dingo, you're a sick man... lol
Old Jan 19, 2010 | 12:03 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Originally Posted by Capthuff
Steve,
Looks good.
Nevermind... google is my friend...
Old Jan 19, 2010 | 12:08 PM
speedyhawk101's Avatar
speedyhawk101
Good info!
Dingo.................not sure what to tell you man.
To Lightweight Battery Install
Old Jan 19, 2010 | 12:11 PM
TheDingo's Avatar
TheDingo
Preaching to the choir man lol
Old Jan 19, 2010 | 04:09 PM
Stevo92z28's Avatar
Stevo92z28
Can only imagine what he was doing up at 4:28 am...
Pete, i got it at summit was like $120.
Old Jan 19, 2010 | 04:44 PM
TheDingo's Avatar
TheDingo
^ thinking about you big guy
