Lumbar Support
Old Jan 18, 2010 | 06:31 AM
relisys48's Avatar
relisys48
Default Lumbar Support
What causes lumbar not to work don't hear pump, or how do you repair lumbar motor?
Old Jan 18, 2010 | 06:42 AM
DeeGee's Avatar
DeeGee
Two likely causes.
Electrical; check the fuse - footwell #3
Leaks in the lumbar pipes. Its rare for the baladder to leak but the joints in the pipes occasionally fracture allowing air to leak. You can pull back the seat cover with the seat still in the car to access the pipework
Old Jan 18, 2010 | 07:07 AM
Hammer99's Avatar
Hammer99
I would have to go check, but I don't recall how much sound the pump motor makes. Yes, your pump can be shot. The bladder can be shot too. Not sure about the difficulty factor of accessability. I know for sure there are threads about replacing the bladder with a blood pressure cuff... try a search.
Good luck & let us know how you do!
Old Jan 18, 2010 | 07:39 AM
DeeGee's Avatar
DeeGee
Originally Posted by Hammer99
I know for sure there are threads about replacing the bladder with a blood pressure cuff... try a search.!
http://forums.corvetteforum.com/c5-g...post1569392984
Old Jan 18, 2010 | 09:01 AM
baggerjohn's Avatar
baggerjohn
I replaced all the bladders in my drivers seat with the small cuffs.
Worked like a charm. Cheap and easy fix !!
Old Jan 18, 2010 | 12:27 PM
Hammer99's Avatar
Hammer99
That is the thread I was thinking of...
Thank's DeeGee!
Old Jan 24, 2010 | 05:28 AM
relisys48's Avatar
relisys48
Default Lumbar
Thanks to DeeGee, baggerjohn, and hammer99. I will try all your suggestions. This forum is the greatest!
Old Jan 24, 2010 | 07:52 AM
oakvillec5's Avatar
oakvillec5
good luck
To Lumbar Support
