Techron Question...
Old Jan 28, 2010 | 11:37 AM
GRUNIE's Avatar
GRUNIE
Default Techron Question...
Is it best to add it to an almost empty tank or a full tank? I've seen it posted here both ways Thanks guys
Old Jan 28, 2010 | 11:49 AM
Jims2001's Avatar
Jims2001
I add mine when the tank gets low 1/4 or less and I am at the station filling her up.
Old Jan 28, 2010 | 12:22 PM
RSchleder's Avatar
RSchleder
Filling after you add the Techron would seem to ensure it mixes thoroughly with the gas. It probably does either way so it's probably not a big deal either way.
Old Jan 28, 2010 | 12:30 PM
GRUNIE's Avatar
GRUNIE
Thanks guys. Anyone else want to chime in??? Don't these cars have duel tanks with a crossover? How can we be sure that both tanks are being treated? With all the sticky fuel gauge issues (I had the problem before the Techron treatment) I just want to be sure to treat the condition correctly. Sorry if this is a dumb question
Old Jan 28, 2010 | 12:34 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I had the gas gage issue where it dropped to zero and the Chack Gages light came on. I had just filled the tank so I added it and within about 5 miles the gage started to work properly. So I guess it does not matter when it is added.
I just thought of this, are you referring to the Fuel System Cleaner or the Fuel Injector Cleaner?
Old Jan 28, 2010 | 12:40 PM
GRUNIE's Avatar
GRUNIE
I belive the Techron Plus (what I'm using) cleans both the fuel system and injectors?
Old Jan 28, 2010 | 12:46 PM
hotwheels57's Avatar
hotwheels57
I add the TECHRON to a half full tank, then top it off and drive it. That thoroughly mixes it up...
Old Jan 28, 2010 | 12:47 PM
jrose7004's Avatar
jrose7004
I add it at the gas station and then fill.
Old Jan 28, 2010 | 01:10 PM
GRUNIE's Avatar
GRUNIE
Okay. Will add the Techron then fill up. Thanks guys
Old Jan 28, 2010 | 04:16 PM
DeeGee's Avatar
DeeGee
The instructions on the bottle say to add the contents of the bottle to a nearly empty tank and then fill up with 12 gallons of gas. I assume that gives the correct concentration. IIRC there are two sizes (12G and 20G) so best check on the size you have bought.
Old Jan 28, 2010 | 04:22 PM
Dominic Toretto's Avatar
Dominic Toretto
I add when it is nearly empty. No problems.
-Alex
Old Jan 28, 2010 | 04:24 PM
GRUNIE's Avatar
GRUNIE
Thanks DeeGee. Though I'm sure I read here before that some guys run their tanks low then add the Techron and let the car sit for awhile (a day or 2?) then add the fuel giving the Techron time to work on the sensors.
Old Jan 28, 2010 | 04:35 PM
DeeGee's Avatar
DeeGee
Cant remember how low the sensor sits in the tank but I guess it must be quite low to work at all. Unless its covered the Techron wont do its stuff. I'd be tempted just to follow the instructions. Cant see that over concentration would be an issue (20G size + 12 gallons) but if you fill to full (18G) you may need the big bottle.
Old Jan 28, 2010 | 04:38 PM
GRUNIE's Avatar
GRUNIE
^^^Good point^^^ If all else fails, read the instructions
Old Jan 28, 2010 | 04:40 PM
DeeGee's Avatar
DeeGee
True but when do we guys ever do that? but just had a look at a pic and its pretty low on the tank. I guess neat techron may be good or bad I'd still give it a shot at the proper concentration first.
Courtesy Armycop2000
Old Jan 28, 2010 | 04:43 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
I take it with me when I'm on my way to the gas station. Then I add it just before I fill 'er up, and throw the bottle away at the station.
Old Jan 28, 2010 | 04:59 PM
GRUNIE's Avatar
GRUNIE
And that's what i'll be doing
To Techron Question...
Old Jan 28, 2010 | 07:40 PM
Ron C!'s Avatar
Ron C!
I just use Chevron gas, never add extra Techron, no guage problems.
Old Jan 28, 2010 | 07:54 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Old Jan 28, 2010 | 07:57 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Dirty little secret:
Most "brand name" gas starts out the same at the wholesale point. additives are added at that point according to what retailer the fuel is going to.
Reason: EPA sets the fuel requirements by geographic area and season and gasoline pipelines all "tend" to offload at the same regional places! If you went to see for yourself you would see branded trucks from many brands and independents in line for their company's "special" fuels!
