convertible ???
Old Jan 30, 2010 | 04:28 PM
  #41
Jet-Jock's Avatar
Jet-Jock
I don't think so. I've never had any problems like that.
I would opt for 01-02, 01 got the most changes for the model years and 02 is probably the perfect year of all C5s.
Verts' have the profile look of the Fixed Roof Coupe/Z06.
I have read about a few here that have had the window fall inside. Of course I don't press down on mine when I'm cleaning it, but haven't experienced that problem either. A new replacement top, the one's I've seen now use the heat seal, as seen on the C6 soft top around the window which prevents that problem with the glass.
You mean what should you look for over all in buying a C5 or just what should you look at for the soft top?
Old Jan 30, 2010 | 04:35 PM
  #42
Kingman99's Avatar
Kingman99
Default Just vert's
Hi
My main concern is only the top and what l should look for? As far as the window falling out OUCH!!!!!!!!!
I would probably go nuts. Being that l am a perfectionist l would have the rear window checked out.
How much is it to replace the rear window with a better one.
Old Jan 30, 2010 | 04:39 PM
  #43
STL94LT1's Avatar
STL94LT1
Love my Vert.!! Also have a hard top for that FRC look.
Old Jan 30, 2010 | 04:43 PM
  #44
Kingman99's Avatar
Kingman99
Default Love that top!!!!!!!!!!!!!!
You happen to have a really awesome vert and the wheels really stand out. Black top/interior?
Where did you get that top and approx how much new??
Alan
Old Jan 30, 2010 | 04:54 PM
  #45
STL94LT1's Avatar
STL94LT1
Yes, black top and interior. The hardtop is a Caravaggio and came with the car.
Old Jan 30, 2010 | 05:26 PM
  #46
joshtownsend's Avatar
joshtownsend
Originally Posted by kingman
Good point l didn't think about it my wife's Audi (vert) has a roll bar system where it will come into play only in an accident or roll over.
If you roll a vette, something terrible went wrong and unless it's a 6 point welded in, its going to do more damage then help...
Old Jan 30, 2010 | 05:31 PM
  #47
bkemp's Avatar
bkemp
Originally Posted by Yoggi
Go topless!!!
Old Jan 30, 2010 | 05:57 PM
  #48
Capt. Mike's Avatar
Capt. Mike
I wouldn't trade my 95 Competition yellow or my 04 Medium Spiral Gray verts for a coupe. As far as the back window issue, I've re attached both of them. It's a fairly simple fix using 3M Windoweld and their glass primer.
Old Jan 30, 2010 | 06:15 PM
  #49
RSchleder's Avatar
RSchleder
What can I say, it's not only RED, it's a Vert
Old Jan 30, 2010 | 06:21 PM
  #50
billyj's Avatar
billyj
I LIKE THE COUPE (targa)
billyj
Old Jan 30, 2010 | 06:30 PM
  #51
Kingman99's Avatar
Kingman99
Nice wheels
Old Jan 30, 2010 | 06:38 PM
  #52
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Thrilled with the vert!!!!
Old Jan 30, 2010 | 06:56 PM
  #53
Jet-Jock's Avatar
Jet-Jock
Hi
Well first a careful examination of the cloth itself. Look for stains, and signs of wear. I would definitely open the top meaning, open the latches move the front to the vertical and the back to the vertical. Examine the weatherstrip both sides and wear on the cloth that rolls the edges. Along each side where the two pieces of weatherstrip split, lift the edge of the cloth and there should be some strips of foam with a sticky backing (you can buy the stuff at HomeDepot places, its just a half inch wide of gray foam with self adhesive.). Many times those come loose, no biggy you can get some new pieces for a couple dollars but know what is there. The idea is when the two pieces of weatherstrip come together this little foam piece adds extra sealant. Examine all the edges and weatherstrip. Look at the underside of the rear corners for wear where it touches the tonneau. Mine had two staples there that factory put in and it scratched the paint. I removed them and put some clear silicone there on the underside to keep the top and the paint from touching. You might see evidence of this or the staple in there. '01 and greater are five layer top I believe so it's very well padded and quiet on the inside. Examine the weatherstrip along the rear underside. I would just touch the window all around and make sure its tight.
Do a search in General for fixing the vert rear window. There's several post on how to do it. Basically you get some glue and glue it back together and use some suction cups to lift the window tight until the glue sets. Not an expensive repair. Several methods on here. Don't worry too much about that, its fairly rare.
You want to apply RaggTop protectant about every 6 months to keep it new looking and bead water. Fairly easy to do.
Make sure the tonneau button opens the cover and makes the windows go down.
Lift and examine.
Old Jan 30, 2010 | 07:19 PM
  #54
RockyF150's Avatar
RockyF150
I'm putting in another vote for convertible for win. It's my first vette and I definitly did not make a mistake in choosing it.
Also Trible black for me was the only way to go. But I had to have 6spd also. No wife to drive. hehe.
Old Jan 30, 2010 | 08:13 PM
  #55
saparr's Avatar
saparr
Roadster is the only way to go..It even has a trunk
Old Jan 30, 2010 | 09:02 PM
  #56
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
I love my vert only for when i go cruising on a warm summer night. nothing beats having the top off and hearing muscle roaring around you!!!
however, i HATE having a vert for my racing. for drag racing, i have way passed the certified cage rules. For road racing, you get all sorts of fluttering of the top and air leaks when going 165 plus.
in the end, i think my best option would have been a coupe. i get the removable top as well as the covered-ness for racing.
Aj
Old Jan 31, 2010 | 12:39 AM
  #57
Cardinal Flyer's Avatar
Cardinal Flyer
Default What?
Guess I haven't been paying attention. They make Corvettes that are NOT straight stick Roadsters? Are they 4 or 6 bangers????
Must be some niche market the MBAs at GM are chasing.
To convertible ???
Old Jan 31, 2010 | 09:53 AM
  #58
Mark I's Avatar
Mark I
IMO any car is better as a vert on beautiful sunny days.
Having said that, I bought mine with the targa because of the particular deal. I think of it as a compromise that provides the best of both worlds.
Old Jan 31, 2010 | 11:01 AM
  #59
oakvillec5's Avatar
oakvillec5
still love mine
Old Jan 31, 2010 | 11:47 AM
  #60
glerma's Avatar
glerma
St. Jude Donor '05
Default Convertible
I drive a convertible every day... love it and I could not imagine anything else being as fun.
