convertible ???
Old Jan 31, 2010 | 11:51 AM
  #61
Jet-Jock's Avatar
Jet-Jock
Originally Posted by glerma
I drive a convertible every day... love it and I could not imagine anything else being as fun.
Yeah it is kind of fun when one leaves to go home from work and you can take a minute to put the top down for a wonderful commute home. Sort of makes you forget and leave the day behind you.
Old Jan 31, 2010 | 11:53 AM
  #62
Baron138's Avatar
Baron138
I would buy another vert in a heartbeat. Ive got the spiral with a black top.
Old Jan 31, 2010 | 12:10 PM
  #63
Rich-L's Avatar
Rich-L
04 Vert is daily driver sun or rain and I love it.
Old Jan 31, 2010 | 12:28 PM
  #64
TooMch's Avatar
TooMch
Originally Posted by Jet-Jock
How easy, it is a piece of cake, flip the two latches, lift the front vertical, then the back vertical, push the button under the tonneau and it releases and puts the windows down lift it up fold the back end in followed by the front and it folds up nicely. Close the tonneau cover. Takes less than 2 minutes. No effort.
I agree it's a piece of cake and the steps above are a detailed explanation of what it takes but even though I do all those same steps they would sound like too much to me reading it. Actually doing it is a total no-brainer and even becomes sort of a rite. I love coming out and taking the top down and not having an automatic top was one of my original concerns. One small benefit of a manual top (beside giving you more trunk room) is that is is super easy to get in and out with the top down. Since you have to put the top up while you're in the car (as far as I know there is no way to do it from outside) with an automatic top it will always be in your way when you enter or exit. Of course you could just leave it down. I put mine up whenever I go into places unless its a restaurant or bar and I can see it from inside. I only latch the drivers side latch during those times so it is an easy one side of the car effort to put it back down.
Absolutely! As it gets close to the end of the day I start getting that good feeling, knowing it's almost time to get out there and put the top down and hit the road. Excellent!
as for road noise, I have no problem talking to my passenger or hearing the radio with the top up or down. Maybe I never expected a Vette whether coupe of convertible to have that sound isolation of a good German sedan. Different types of vehicles.
Get the vert. I wanted a manual and ended up with an automatic. It did not have the performance axle either. That was not a good combination. I had to put 3:42 gears in and a higher stall torque converter and got a good tune and now I really enjoy the automatic. I still would like to own a manual, at least for a while to see how it fits me. I've considered changing mine over, but I'd really like to get a non-vert 6spd to use for track events. I do drag race my vert at times and haven't noticed any issues with the top being up - noise-wise or stability and solidness of the top. I have noticed some extra wind noise with the top up from the windows not sealing perfectly and heard that window tip in is the place to look for a fix. It hasn't bothered me enough to pursue though because since its kind of an art I'm afraid of making it worse.
I say get the Vert, get either tranny. You'll still be driving a convertible Vette and that is one sweet ride. Color. That's totally personal preference. When I was looking for mine. I was going to get any color except red. I ended up with red and I'm quite pleased. red with black top, black int and some accents around and I think its sweet. The black top is very easy to take care of.
Good luck!
Old Jan 31, 2010 | 01:50 PM
  #65
T&C Conv's Avatar
T&C Conv
Originally Posted by cdnguyred88
Coupe if you need to carry a lot of stuff, Vert for pure pleasure...
Not so! I live in Texas and my wife and I take it to Chicago (our old stomping grounds). We can get two suitcases and a lot of other stuff in the trunk. We also go on the Hot Rod Power Tour and have no problems. Maybe you need some packing lessons.
Old Jan 31, 2010 | 01:54 PM
  #66
1FINE99's Avatar
1FINE99
Cruise-In IV Veteran
Cruise-In V Veteran
Love our vert!!
Old Jan 31, 2010 | 02:20 PM
  #67
tonyb47's Avatar
tonyb47
Last spring I went thru the same process. I belong to a car club and a member with a 2004 triple black conv said get a vert. I found a black 2000 vert black top and oak interior and and just love it. The best is cruising with the top down in the summer evenings. Nothing like it.
wouln't get anything but a convertible. get one you will never regret it.
Old Jan 31, 2010 | 02:28 PM
  #68
Kingman99's Avatar
Kingman99
I also noticed some verts had the hardtop, was this from GM or the place in Canada with a C???
Old Jan 31, 2010 | 02:35 PM
  #69
Jet-Jock's Avatar
Jet-Jock
I suppose I should disclose I'm a bit biased.
Old Jan 31, 2010 | 02:40 PM
  #70
cdnguyred88's Avatar
cdnguyred88
I have no problems nor does my Wife. But I have seen some spouses that could fill the trunk by themselves.
I owned a '88 Coupe for 13 years and now the Vert. I could never go without a Roadster from now on.
Old Jan 31, 2010 | 02:48 PM
  #71
STL94LT1's Avatar
STL94LT1
There were no C5 factory hardtops.
Old Jan 31, 2010 | 03:11 PM
  #72
Aerovette's Avatar
Aerovette
Originally Posted by STL94LT1
Love my Vert.!! Also have a hard top for that FRC look.
How does this top attach at the back?
Old Jan 31, 2010 | 03:22 PM
  #73
STL94LT1's Avatar
STL94LT1
The top has a hook on each side that attatches to a bracket that is secured by the seat belt bolts.
Old Jan 31, 2010 | 03:57 PM
  #74
Kingman99's Avatar
Kingman99
Default Real neat hard top
[QUOTE=STL94LT1;1572940418]The top has a hook on each side that attatches to a bracket that is secured by the seat belt bolts.[/QUOTE
Hi
The only person that does this is Caravaggio up in Canada, where did your top come from and would know the approx price??
Just love the idea!
Thanks]
Old Jan 31, 2010 | 04:15 PM
  #75
STL94LT1's Avatar
STL94LT1
It is a Caravaggio top, and came with the car. From what I've read the top with shipping and getting it painted will cost ~$4k.
Old Jan 31, 2010 | 04:22 PM
  #76
Kingman99's Avatar
Kingman99
Default Well worth it!
Hi
It is awesome and the company Caravaggio is top notch. It's worth the trip up to Canada to have it done properly. The price ticket is high for what it is but again if you live in Canada there is no other choice!
Alan
Old Jan 31, 2010 | 05:05 PM
  #77
SSWEET's Avatar
SSWEET
I've got a 99 Vert......wish I had a 99 FRC instead.........
Old Jan 31, 2010 | 05:07 PM
  #78
Extreme C5's Avatar
Extreme C5
Vert is the only way to go on a vette!!!
