AC-Delco OEM Pads
My Z06 rotors still stop smooth, but I have notice a defininte lip on the outside edge of the rotors due to the pads wearing the rotor.
I think GM even recommends that rotors not be turned routinely, but only if there are deep grooves in the rotor. I was wondering if I should at least machine the outer lip off before installing new pads.
But yes I will just swap the pads leaving the rotors alone. You are correct in regards to the rotors, however, don't be surprised if you get a lot of arguments on turning rotors. The lip is there when they are new.
If you are concerned, mic the rotors to see what you have left. Maximum scoring depth is 1.5 mm.
Front minimum is 30.6 mm, throw-away at 30.3 mm.
Rear minimum is 24.9 mm and throw-away is 24.5 mm.
The important part of the brake job (pad swap) is bedding the pads afterwards. GM recommends 20 stops 0-30mph bring to a stop and repeat 20x. At about the 18th stop you'll start to smell them and after 20 return to your location and allow them to cool down. You'll be good to go.
What did GM put on my 03Z that makes them turn the wheels black in a few days. Can't keep these clean. They have lasted well but man are they dirty and noisey.
I prefer to use the procedure established by Chevy engineers for their vehicles.
The lip is there. It won't be as pronouced as say a rotor with 50% life remaining.
at 80,000 miles I am still using the original OEM pads.,. they now have 3/32 on them and would pass inspection but I'm going to replace them with the same thing.. these pads are soft and have a high coefficient of friction with the least amount of increased rotor temp... consider the put ceramic tiles on the space shuttle to help absorb reentry temps. Ceramics are designed for supper hot temps. Unless you are doing a road coarse, your steet car would never see more than 800 F where as a road race car can see 1800 F...turn cherry red... this like the space shuttle is a correct application.. but Not a street car.. you actually need to heat the pads up to make them stop as well as the stock pads when cold..you of course do not feel this because you have a brake booster. but if you didn't, you would have to stand on the brake pedal with ceramics.
Here is one of a few shot Ive posted more times than I should have but this shot was taken when the pads were 8 years old and the rotors were 6 years old and the rotors had 60,000 mile Taken a 2 years ago. No discoloration what so ever
EXIF INFO.
Date Taken: 2008-03-27 18:12:52
Camera: SONY DSLR-A700
Exposure Time: 0.0166s (1/60)
Aperture: f/5
ISO: 1600
Focal Length: 28mm (42mm in 35mm)
Photo Dimensions: 1459 x 1165
File Size: 259.47 KB
JPEG Quality: 8/18
Flash: flash fired, compulsory flash mode
Metering: pattern
Exposure Program: aperture priority
Exposure Bias: 0 EV
Here is a shot taken yesterday car is 11 years old , original OEM pads, 80,000 miles
EXIF INFO:
Date Taken: 2010-03-10 15:53:42
Exposure Time: 0.025s (1/40)
Aperture: f/5.6
ISO: 200
Focal Length: 55mm (82mm in 35mm)
Photo Dimensions: 4272 x 2848
File Size: 8.28 MB
JPEG Quality: 8/18
Flash: flash did not fire, compulsory flash mode
Metering: pattern
Exposure Program: shutter priority
another trick is having very clean wheel wells..having clean wheels wells makes the car look like it just rolled off the car carrier.. Its also nice to be retired.. its very hard for anyone to believe that I haven't touched those rotors in two years, I do blow then out with hp air from my compresser.. the two sets of photos where proof that my four corners look better than new... and they do... I see new C6's with drill rotors and they are all rusty..and they should be because they are sitting out in the dealership getting wet and rusting.. but when I pull my car next to a C6 with 8 miles on it, my car look newer..So I owe the shine to many months of waxes originally. I would not call it a garage queen, because it has 80,000 miles on it ad its 11 years old. I was telling my wife just tonight that I could go out and buy a new Corvette, but why should I spend the money when I am perfectly happy using that money to spoil my grandchildren , and fly up to see my other grandchild 4 or five times a year.. If the car felt old to me or didnt give me the buzz I had when it was new then I would consider a new car. the fact that I do not drive it all the times, make getting into iot and starting it up a real joy, and even after 11 years some people have the audacity to ask me if it was brand New.. and this is usually every time I take it out..I know it sounds far fetched, but its very ture to my amazment. there isnt a day that I take it out that someone doesnt have a nice comment or a thumbs up.. The Real End
EXIF INFO.
Aperture: f/5
ISO: 1600
JPEG Quality: 8/18
Metering: pattern
Exposure Bias: 0 EV
EXIF INFO:
Aperture: f/5.6
ISO: 200
File Size: 8.28 MB
JPEG Quality: 8/18
Metering: pattern
That was a great write up on using the Zaino & using the OEM pads for street use. Your rotors are super shiney & so is your paint.I was wondering if you use the 8 hp black blower with heated air controls that is advertised on this forum? I believe they sell for about $300
Retired guys rock.
Thanks for any info. provided
robsc501
Retired guys rock.
robsc501
