steering column lock
Old Jan 31, 2010 | 10:42 PM
earroyo48's Avatar
earroyo48
3rd Gear
Default steering column lock
hey fellas, my problem is that i had my steering column lock pin removed
in early '09 and now the column lock message is coming on again, and my car shuts off. i did leave my key in the ignition for about twenty minutes before i was to park it, and thats when it started. any suggestions?
Old Jan 31, 2010 | 11:44 PM
8VETTE7's Avatar
8VETTE7
Two choices:
1) Install a CLB. That will get rid of the error messages and the fuel shutoff.
2) Reprogram fuel shutoff speed in PCM to a high number (255). That gets rid of the fuel shutoff problem but NOT the error message. Then either live with clearing the error message every time you start the car or use choice 1. Only programming tools that can reset the fuel shutoff speed are EFI Live or HP Tuners.
Old Feb 1, 2010 | 12:38 AM
Easier to do the CLB.
Old Feb 1, 2010 | 12:52 AM
itzza427's Avatar
itzza427
Get it,,install it,,THEN you can forget it!!
Old Feb 1, 2010 | 01:02 AM
ronssito's Avatar
ronssito
I installed the CLB last week in ~2 hours. The hardest part was finding the correct Torx bit.
Old Feb 1, 2010 | 01:14 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Get the CLB kit and install it.
Here are some helpful links....
Install a Column Lock Bypass:
http://97vette.com/howto/columnlock/index.html
http://www.ls1howto.com/index.php?article=24
You can get a CLB from either of these vendors:
http://www.corvettesofhouston.com/pr...e9bf70207aef69
http://www.thunderracing.com/catalog...d=220&pcid=156
Old Feb 1, 2010 | 02:29 AM
DeeGee's Avatar
DeeGee
Couldn't agree more
CLB is a $50 mod and you'll be done with it forever.
Old Feb 1, 2010 | 07:23 PM
earroyo48's Avatar
earroyo48
3rd Gear
thank ya'll vette guys! i just ordered my CLB.
i appreciate your speedy response
To steering column lock
