Cold air screens
Old Mar 6, 2010 | 02:40 PM
billyj's Avatar
billyj
Default Cold air screens
can i get some info on installing these screens???
is it a one beer or a six pack to do this.
any advice will be greatly appreciated.
purchased from west coast corvette,
GOOD PEOPLE,FAST SERVICE
THANKS
BILLY
Old Mar 6, 2010 | 02:42 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
The ZO6 screens?
Old Mar 6, 2010 | 02:57 PM
billyj's Avatar
billyj
they are the screen's to let air in by the fog lights.
about 1/2" mesh openings
thanks
billyj
sorry they are not
Old Mar 6, 2010 | 03:03 PM
IRON MAIDEN's Avatar
IRON MAIDEN
???????? No clue what you are talking about. Try posting a pic of what you have.
Old Mar 6, 2010 | 03:08 PM
billyj's Avatar
billyj
they are to replace the plastic housing around the fog lights.
thanks
Old Mar 6, 2010 | 03:11 PM
Dave68's Avatar
Dave68
The screens themselves are very easy to install. Removing the fog light covers is a whole "nuther" ballgame. Many folks core holes in the FL panels and then install the screens, which is a 20 minute job at most.
Old Mar 6, 2010 | 03:12 PM
Daddyrama31's Avatar
Daddyrama31
You will need to lift your car. 3 bolts hold them in. They are kind of tough to get to. Its not that complicated. Two bolts on one side and one on the other. Pull the old ones out, pop the new ones in.
Old Mar 6, 2010 | 03:13 PM
billyj's Avatar
billyj
i guess i have to remove fog light covers????
thanks
Old Mar 6, 2010 | 03:16 PM
GOTHAM VETTE's Avatar
GOTHAM VETTE
you'd be lucky to finish a half a beer.....unless you want to turn it into an all day drunken event....
Old Mar 6, 2010 | 03:27 PM
billyj's Avatar
billyj
i'm a cheap date,two heinekin's will due me in.
looks like it will take a couple of days ha ha
billyj
Old Mar 6, 2010 | 04:01 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Are you referring to these screens?
I never removed anything associated with the fog lights. They went in in less then 10 minutes. They are held in with double sided tape.
Old Mar 6, 2010 | 04:41 PM
billyj's Avatar
billyj
no i am talking about the fog light holders
i don't have the z06 screens. i will replace the plastic piece.s
in the center of thegrille?????
billyj
Old Mar 6, 2010 | 04:42 PM
billyj's Avatar
billyj
it will be the holders behind the screens
billyj
Old Mar 6, 2010 | 04:53 PM
tremor1's Avatar
tremor1
Old Mar 6, 2010 | 04:56 PM
billyj's Avatar
billyj
i got htese from west coast corvette's stk#11104229 cold air screens
i got directions from the web site.
thank you for all your help
billyj
Old Mar 6, 2010 | 05:25 PM
AU N EGL's Avatar
AU N EGL
Just take a utility knife with a fresh blade and cut out the back side of the plastic. Just cut along the transition of the flat back to the curved part. Then by the fog light there is a small notch. Just cut a straight line down from the notch.
then take the screens and use double sided sticky tape. Done in 45 min max
Old Mar 6, 2010 | 05:41 PM
04 commemorative
St. Jude Donor '17
I installed my screens in 10 minutes. Mine right now are for looks only but one day when I feel like it I will remove them and drill a few 1" holes then reinstall the screens. I also used double sided tape and they have been in now 5 years
To Cold air screens
Old Mar 6, 2010 | 06:30 PM
American Hydrocarbon
Guest
Posts: n/a
Just take a 2" hole saw and drill three holes in each of the stock ones. Takes about 20 minutes. Then return the ones you purchased.
Old Mar 6, 2010 | 06:52 PM
Daddyrama31
Me again. I dont think these are the exact ones you purchased. However, the proceedure is the same.
http://www.magneticred.com/mods/coldair/index.html
Old Mar 7, 2010 | 07:57 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
This is correct. These are not the easiest screens to install (like the others). They look cool though and definately help get cool air into the motor. One bad thing is.. they let dust and dirt in too. I immediately noticed a difference with them with the Blackwing.
