Harmonic balancer????
Old Mar 7, 2010 | 11:47 AM
sorbet70's Avatar
sorbet70
Default Harmonic balancer????
Well after a 3 month sleep, today was the day to take the vette out.while driving i turned the AC on and noticed a belt burning smell.turned around and when i got home,popped the hood and noticed a slight wobble from the crank pulley.i know this is a common problem with the c-5.so here is my??can i just tighen up the bolt or replace the whole pulley?if i must replace how much would the dealer charge??
THANKS IN ADVANCE
Old Mar 7, 2010 | 12:18 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Time to replace. Not a fun job. The demon (steering) rack has to come out. When I had mine done I upgraded with a better balancer and also pinned the crank, just in case I ever want to install a blower that part is already done.
I would stay away from the stealer ship and find a good Corvette shop. Englandgreen did mine.
Good luck with the repair.
Old Mar 7, 2010 | 12:24 PM
JeepTJ's Avatar
JeepTJ
Some pics of the install. Here is the new balancer.
Pic of Stangkiller under my Vette.
Old Mar 7, 2010 | 12:25 PM
tail_lights's Avatar
tail_lights
Spot on!
Old Mar 7, 2010 | 12:50 PM
born2drv's Avatar
born2drv
Just had mine done. Dealership quoted me about $800 parts and labor. Had a local corvette shop do it for less then 1/2 of that.
Old Mar 7, 2010 | 01:31 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The harmonic balancer is a problem on all of the LSx engine cars, and they fail...simple as that.
I'm fortunate to not having a failure - yet. But when (notice I said when not if...) it does fail - I will have an aftermarket unit installed like the one from ATI - http://www.atiracing.com/products/da...ts/damserp.htm
As mentioned, it is a pretty complex job to tackle at home, but it certainly can be done. I can't tell you off the top of my head at home what Xtreme would charge without looking it up - but it's about 6 to 7 hours of labor (maybe a little less for an experienced tech with a lift and the right tools) I think.
Old Mar 7, 2010 | 03:19 PM
sorbet70's Avatar
sorbet70
thanks all for the reply.i just went out for another ride and noticed no more burning smell.is a little wobble normal on the pulley for these motors?
Old Mar 7, 2010 | 04:28 PM
BobbyG123's Avatar
BobbyG123
You should see NO wobble, it will get worse over time and could leave you on the side of the road
Get AAA and they can tear your car up when they load it up on the flat bed
New one in the parts and I think he wants 80.00 for it.
Just check with shops that works on vettes and get it fixed before it goes bad and mess something else up
Old Mar 7, 2010 | 04:40 PM
JeepTJ's Avatar
JeepTJ
If you open the hood of most C5s, I think you will see some wobble, so normal, Yeah. but once they start to wobble they have gone bad. These have been known to come apart and fly through the hood. That takes a small job to a huge job. I would look into getting it replaced ASAP.
Smelling smoke come off the belts was not a good sign. See is talking to ya.
Old Mar 7, 2010 | 06:43 PM
joshtownsend's Avatar
joshtownsend
I would also get a 8 rib if you even think you might get blown.. I believe there are the same price at ATI.. but i could be wrong...
You can run a 6 rib belt on it for now.
Old Mar 7, 2010 | 06:54 PM
sorbet70's Avatar
sorbet70
couple of vette gurus from other forums say that a little wobble is normal, in fact if dealer replaces it with a GM pulley they also wobble a bit.i just looked at the pulley on my 09 jetta while running and its so straight it looks like its not moving.
All work and no play makes Jack a dull boy.........
Old Mar 8, 2010 | 03:30 PM
azzhauler's Avatar
azzhauler
What options are out there for aftermarket pullies? I've noticed mine wobbles a bit more than I'd care to see now.
Old Mar 8, 2010 | 05:16 PM
M_T_0's Avatar
M_T_0
Hmmm 20lb of metal spinning at 5000rpm and it is wobbling (just a little), when its failure mode includes coming thru the hood or bouncing around inside taking out 1/2 of the engine bay.
do yourself a favor and just buck up for a good replacment (not OEM) and call it insurance.
Old Mar 9, 2010 | 05:01 PM
sorbet70's Avatar
sorbet70
Does anybody know a good shop on LI NY for this job or should i take it to the chevy dealer.i have been going to ramp chevy but they went south......
Old Mar 9, 2010 | 05:10 PM
PostShawn's Avatar
PostShawn
I had mine replaced at a vette shop in town. They had a used balancer pulley that was just fine laying around the shop. They basically gave it to me and did the install for pretty cheap. I forgot the price but it was I think it was about 250 bucks or something.
I was still pretty new to owning the vette at the time it happened. I used to use a Firestone shop near my work at the time before the vette so I figured since it was on the way to work I would get it there. I was able to drive it there but that was about it on driving it. Firestone looked at it and said they couldnt work on this caliber of car although they had a Porsche on the lift at that moment. I said fine and had a tow truck bring it to my vette shop and they had it done by the end of the day. If Firestone didn't want to work on it I wasn't going to force a mechanic to work on something they didnt want to and better even didnt know how to. So I would say if you have a vette shop in the area they will have the most experience with this sort of thing so bring it there.
good luck
Old Mar 9, 2010 | 05:19 PM
Vette_Minded's Avatar
Vette_Minded
Danmit, Iv'e noticed what looks like a wobble on mine @ 4900 miles. My belt squeeks a little at startup but goes away after the car warms up. I was hoping that it was just the belt or maybe an idler pully.
The wobble looked like it may be addd weight on one side but I can't tell. Will the belt move back and foth or can you tell?
Old Mar 9, 2010 | 06:13 PM
sorbet70's Avatar
sorbet70
I have been doing a lot of research on this subject from this and other forums, and from what i read a LOT of c5 vettes since new have a wobbling pulley.the ?? is whats normal and whats not.i have read that installing a new GM pulley will also wobble.so i think im gonna play it safe and take it in.i also have come to the conclusion that these cars are really built lousy between this,pistonslap, columlock,rocking seats, its all starting to take the fun out of corvette ownership.
To Harmonic balancer????
Old Mar 9, 2010 | 07:07 PM
born2drv's Avatar
born2drv
I had a local corvette shop replace mine... but they modified it (I think they pinned or keyed the pulley or something) so that it would not back out on it's own anymore. Take it to someone who has lots of experience with the car, not someone who will simply replace a poorly designed/installed part with another in the same fashion to give you the same problem.
Old Mar 9, 2010 | 09:09 PM
kid81's Avatar
kid81
I paid 700.00 for my replacement from a local garage..
Old Mar 9, 2010 | 09:36 PM
Vette_Minded
How hard is it to change? I went out and looked at it just now and when I a light on it is wobbling pretty bad.
