intake question
Old Mar 29, 2010 | 09:17 AM
jayd25's Avatar
jayd25
Default intake question
Was wondering what intake a 2004 regular vette has?Talked to a cpl of people and they say they have a ls6 intake.I believe them but want to make sure cause I was gonna buy a ls6 intake and ported throttle body.Thanks
Old Mar 29, 2010 | 09:26 AM
Jims79's Avatar
Jims79
99.99% sure that all vette's after 2001 to 04 have the LS6 intake. And unless you go to a fast 90 & 90mmTB you will not gain any real HP from a ported OEM TB.
Old Mar 29, 2010 | 09:27 AM
AU N EGL's Avatar
AU N EGL
yup 2001-2004 all have a LS6 intake.
Old Mar 29, 2010 | 10:51 AM
jzemo's Avatar
jzemo
LS6 intake...if your looking to upgrade go with the FAST 90 and throttle body, ported and polished of course!
Old Mar 29, 2010 | 11:35 AM
The '01-'04 C5s all have the LS6 intake on them. Was a nice upgrade from the prior years' intakes.
Old Mar 29, 2010 | 03:03 PM
Dave68's Avatar
Dave68
I recall reading in this forum that not all 2001s had them - only the later-built ones. My 01 has the LS6 intake and was built near the end of the 01 production run.
Old Mar 29, 2010 | 03:07 PM
BTow1105's Avatar
BTow1105
I was under this impression as well...
Old Mar 29, 2010 | 03:21 PM
jrose7004's Avatar
jrose7004
My 04 has the LS6 intake and so does yours!
Old Mar 29, 2010 | 04:22 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
with stock cam/heads waste of money. You'll get some more power, maybe pick up a few HP...but not worth it IMO. Kind of like putting on AFR heads, but leaving the stock cam in.
Old Mar 29, 2010 | 06:06 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
ls6.....you'll be good with that one
Old Mar 29, 2010 | 06:12 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
My 01 HAD one , but the FAST 92 took its place
Old Mar 29, 2010 | 06:28 PM
fun01's Avatar
fun01
How would you know ? Option code, perhaps ?
Old Mar 29, 2010 | 06:37 PM
0331MARINE's Avatar
0331MARINE
Just look at the part number on the intake manifold
Old Mar 29, 2010 | 06:45 PM
fun01's Avatar
fun01
Thanks for the info, but what do I cross reference this number to ? Which one are you showing here ?
Old Mar 29, 2010 | 07:00 PM
dobewillie's Avatar
dobewillie
Ported fast 92 took mines place
Old Mar 29, 2010 | 08:52 PM
HowlinC5's Avatar
HowlinC5
that would be the one above where it says "Firing Oder"
Old Mar 29, 2010 | 08:56 PM
0331MARINE's Avatar
0331MARINE
That is the LS6 manifold I took off my 01.
To intake question
Old Mar 29, 2010 | 09:31 PM
AUandAG's Avatar
AUandAG
My '01 was built 11/02/00. The intake manifold part number is 12561182 which is also a valid LS6 part number.
Old Mar 29, 2010 | 10:00 PM
ramez75's Avatar
ramez75
Where do you look for this info. Do i have to take something out to be able to see the number/info in the picture
Old Mar 29, 2010 | 10:05 PM
ramez75's Avatar
ramez75
