[Z06] Looking to purchase ZO6 Automatic
Apr 4, 2010 | 01:19 PM
2nd Gear
I am looking to purchase 01 to 04 ZO6 in difficult to find Automatic under 30K miles any color except black - prefer red. Will arange for carrier to Maryland. Private party.
jcknicker@verizon.net .
Apr 4, 2010 | 01:21 PM
You will probably have an interesting time finding that considering all Z06's are 6-speed..........
Apr 4, 2010 | 01:47 PM
Try finding the one with the ls9 option while you are at it !!!! I heard the run quicker times !!!
Jk man a Z06 with and auto will b nice to have
Apr 4, 2010 | 02:21 PM
2nd Gear
My thread - C6s only option is 6 speed. C5 GM data sheet I viewed listed automatic as an option over standard 6 speed as it was still a small block. Wrong?
Apr 4, 2010 | 02:26 PM
WRONG.
the C5Z06 were ALL 6 speed manual. No automatic C5 Z06s were made by the factory.
C5 Coupes and convertibles could come with an Automatic or 6-speed manual
C6s come in Automatic or manual.
Apr 4, 2010 | 02:56 PM
No factory automatic Z06. Ever.
Apr 4, 2010 | 04:12 PM
Quote:
Originally Posted by
irvbulldogs72
Be it C5 or C6!
Apr 4, 2010 | 05:45 PM
Apr 4, 2010 | 06:25 PM
Jansen
The 7.0 is still a small block. small block/big block lingo doesn't apply in LSx Land.
There is a larger displacement (BIG BORE/STROKE) to be had but no physical difference in the Block.
Apr 4, 2010 | 06:44 PM
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
In fact, If I remember correctly, the FRC from 99-00 was also a 6-spd manual only as well. I could be mistaken on that though.
But as others have said.. all Z06s, no matter if it was an 01-04, or 06-present are manual cars.
Apr 4, 2010 | 07:23 PM
You are correct. The 99-00 FRCs were all 6 speeds.
Apr 4, 2010 | 08:39 PM
I think all the convertible Z06s were standard with an automatic
Apr 4, 2010 | 10:07 PM
Novat_99
you forgot the 383 ci that was standard too
Apr 4, 2010 | 11:05 PM
as a former GM tech I can tell you that all FRC'S ever built came ONLY with a manual trans
Apr 5, 2010 | 04:06 AM
2001 spec sheet
Apr 5, 2010 | 06:26 AM
U might be able to find someone who had a conversion to automatic I've seen a few the idea seems pretty lame though
Apr 5, 2010 | 09:20 AM
sslowss
Drag racers and people with disabilities which don't allow them to use both feet.
Apr 5, 2010 | 09:55 AM
irvbulldogs72
Buy a coupe with auto
Apr 5, 2010 | 10:21 AM
sslowss
FRC is lighter and more rigid. The one I'm thinking of also has a 427 in it and runs 9s. Can you shift your way into the 9s? And then be consistent enough to run a bracket or an index on top of that? Didn't think so.
Apr 5, 2010 | 10:49 AM
Actually yes people have not me personally but you should do some reading and if you want to do that why do it with a z06 that's built for the road race?
