Need advice for engine knock/ping
Old Apr 6, 2010 | 07:19 PM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
Default Need advice for engine knock/ping
Last year I put in a new air intake, GHL's and had professionally tuned.
The Vette runs great, but at around 2300 rpm's I get the pinging sound. At no other time does it do this. There are no codes appearing.
Should I sea foam for carbon build-up, change the knock sensor or ???
Any valid ideas or suggestions are welcome.
Old Apr 6, 2010 | 07:35 PM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Who tuned it? I would go back to the tuner first.
Sounds like too much timing or too lean.
Nick
Old Apr 6, 2010 | 07:43 PM
Chicago1's Avatar
Chicago1
Could be a million things best bet is take it back to the tuner and have him log it and see what the log looks like. Post up a run file if you can
Old Apr 6, 2010 | 08:28 PM
killain's Avatar
killain
Oldtimer
It not a piston slap, I'd be sure to stop by the tuner. Sounds like it's a little too lean. Does it run hot, or hotter than it did before the tune?
Old Apr 7, 2010 | 12:00 PM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
Thanks, I'll have the tuner check it.
Old Apr 7, 2010 | 12:45 PM
bucwheat's Avatar
bucwheat
You are using premium gas right?
Old Apr 7, 2010 | 12:57 PM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
Yes. Nothing but premium gas, but I am running tank empty and filling with a different brand to try that.
Old Apr 7, 2010 | 02:14 PM
DeltaBravo's Avatar
DeltaBravo
I get some pinging when I haven't driven it hard for a while. I usually just put my foot in it once or twice and "blow it out" - goes away until next time. If I remember to goose it every time I head out, it stays away. So, you could try a couple WOT passes to see if this helps. If not, then Seafoam/Techron combo in the fuel tank might do it; it worked for me when I had the dreaded fuel sender issue and it helped clean up the combustion chambers quite well. Having said all that, a trip back to the tuner would surely fix it, I hope.
To Need advice for engine knock/ping
