Need Instructions for Hurricane Intake
Apr 18, 2010 | 12:48 PM
Last time I attempt to do the install I went from the top to install it but it was not working. Do I have to put it in from bottom?
Thank you.
Apr 18, 2010 | 04:45 PM
just installed mine yesterday. it takes a little effort, but it will drop down from the top
Apr 18, 2010 | 08:09 PM
I see on the sides of the system there's a hole on each side but I don't see any spot on the car for that to line up too. Do you make new spots ? It seems like the 2 air flow spots on the 1st peice doesn't fit correct. There's no cuttng? Thank you.
Apr 19, 2010 | 01:07 AM
No, no cutting needed. The 7 holes at the bottom match up to the ones that were used for the stock radiator shroud.
Apr 19, 2010 | 05:23 AM
Here are the instructions from WCC:
http://www.westcoastcorvette.com/fil...5Hurricane.pdf - may take a while to download the PDF.
It installs from the top, but you will also have to get underneath the front to remove/install screws, etc. Takes more cuss words than tools!
Apr 19, 2010 | 11:34 AM
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
I did mine from the top but man what a pain to install that intake!
Apr 25, 2010 | 10:13 AM
Thanks to all, especially to Choreo. Couldn't get to it this weekend but I'll let you all know how it goes next weekend. Thansk again.
Feb 4, 2023 | 10:43 AM
Quote:
Originally Posted by
1SHADYZ
Found original install instructions
Page 1
Page 2
2008 ,
c5 ,
c6 ,
corvette ,
hurricane ,
hurrincane ,
inst ,
install ,
installation ,
installing ,
instrrstions ,
instructions ,
instrutions ,
intake
