door lock problem
Old Apr 18, 2010 | 11:02 PM
rpmoody's Avatar
rpmoody
Default door lock problem
Does any one know about or heard of a c5 that honks and locks the door on its own? My 1999 started doing this the past month. Occasionally while the car is parked in garage I hear the horn sound. Yesterday when I got out at the gas station to fill up I shut the door with the key in the ignition and the horn sounded and locked me out.
After standing there for about 10 minutes the horn sounded about 5 times and then I heard the click of the door unlocking. Needless to say I won't be leaving the key in the ignition again until I get this fixed. Thanks for any insight into this problem.
Old Apr 18, 2010 | 11:07 PM
Bill Vett's Avatar
Bill Vett
New battery or switch off the passive switch???
Old Apr 19, 2010 | 03:36 AM
Or the fob could be going bad.
Old Apr 19, 2010 | 08:41 AM
8VETTE7's Avatar
8VETTE7
Passive mode on the key FOB. Turn it off and it should get better. If not replace the FOB with one from a 2000. That year GM did away with the passive mode and that is the last year compatible with the early cars (1997 - 2000).
To door lock problem
