HID Beam Pattern Test
"That's the vertical adjustment (there is no horizontal adjustment). On a flat level surface, set the car exactly 25 feet from a wall. Mark a horizontal line on the wall the same height as the HID capsule. Turn on the lights and adjust the screw until the very top of the bright zone touches the line you just made."
Originally Posted by RPOZ4Z
the "sweet spot" seems to be around 24 1/2" to 25" about 3 feet from the front bumper.
also depends if your car is lowered or not.
Originally Posted by jdmvette
i have also used an easy trick that is available since these bulbs have such a sharp cutoff.
i have taken my car around the block at night and checked to see if the lights shined into the cars that are parked on the street.
if i could see that they were shining into the windshield, i lowered them. now the cutoff does not go above the belt line of most cars that i passed and even then it's still below the window line.
it's not exactly scientific but it worked for me and i don't get any flashes.
I like to aim from 25' or more on a level surface onto a white wall.
Vertical adjustment: the low side (left side) of your stepped cutoff should be between 22" and 24" from the ground. (If your car has been lowered, drop this to 20-22" depending on how much lower your car is)
Both left and right headlights should be aimed so the low steps line up.
Horizontal adjustment: The "step" is the center of the beam They should fire straight forward. To verify this, stand behind the outer tail light on either side with a plumbline or a straight stick. There should be a straight line between the outer tail light, projector and the center of the cutoff.
Should end up similar to this:
Here's a How To I put together from the manual which should help. Just ignore the first part about the stock lights.
Aiming your Head Lights
Preparation:
Prepare the aiming area. You can use the garage wall providing its at least 25’ from the car and the ground is level.
Mark some calibration lines using chalk or masking tape:
Find the center of the headlight and measure the distance to the ground. Mark a horizontal line on the surface (garage door or wall) using masking tape at the same distance from the ground.
Stick a piece of tape in the center of the windscreen and another on the rear glass to use as reference marks.
Line these up from behind the car and use them to mark the centerline of the car on the wall.
Measure the distance between the center of both headlight lenses and use this to measure from the center point you just marked on the surface.
Make sure the tire pressures are correct and the tank is full or the calibration may be out. Park the vehicle square with the aiming surface. Close the doors and rock the car to stabilise the suspension.
Lubricate the adjusting screws and let them sit for a while
Adjustment
Horizontal and vertical aiming is done by moving the adjusting screws which moves the headlamp capsule in relation to the headlamp frame. The horizontal adjustment screw is located on the inboard side of each of the headlight assemblies and covered by a plug. The vertical adjustment screw is located on the inboard side of each of the headlight assemblies below the lower edge of the headlamp bezel. Its a long golden rod. I think it’s a #15 torx.
Raise the hood.
Raise the headlamps.
Remove the headlamp adjustment screw plug from the headlamp bezel. Reach under the headlamp bezel and push out the plug from behind.
Turn ON the low beam lamps. Block the light from the passenger lamp to allow you to adjust the drivers lamp. Don’t cover the headlight or it may get too hot.
Inspect the horizontal aim. Make the adjustments with reference to the lines and numbers on the aiming chart below
Adjust the aim using the horizontal adjusting screw, to align the break point (3) of the high intensity zone to the headlamp vertical centerline (1), within the range of 38 mm (1.5 in) to the left (5) of the lamp vertical centerline (1), to 38 mm (1.5 in) to the right (4) of the lamp vertical centerline (1) on the aiming screen.
Inspect the vertical aim.
Adjust the aim using the vertical adjusting screw, to align the upper edge of the beam horizontal cut off line 114 mm (4.5 in) below (7) the headlamp horizontal centerline (2), within the range of 76 mm (3 in) below (8) the lamp horizontal centerline (2), to 191 mm (7.5 in) below (6) the lamp horizontal centerline (2) on the aiming screen.
Install the headlamp adjustment screw plug. Push to secure.
Turn OFF the headlamps.
Lower the hood.
Your light pattern should look roughly like this when you’re done.
Thanks to Junkman for his pics
The idea behind the cutoff is that you can aim your beam higher and with more precision without blinding other drivers.
HIDs in a reflector (like the plug and play kits) have this pattern:
These you would aim using the traditional OEM aiming chart.
HIDs in a projector (like the light cannons) have this pattern:
This is my personal setup: E55 Bi-X projectors with ZKW lens, modified shield and color spacing.
I cut the shield to drop down a little lower on the passenger side. This is just my personal preference
I noticed a big difference between my Euros and the stock US lights. As with the HIDs the Euros have much better beam shaping.
Note, the T84s are NOT HID friendly. The pattern gets all gross-like
I offer two kits Fixed and pop up:
