LS6 Engine Rebuild Question
Old May 15, 2010 | 11:07 AM
wallifishrmn's Avatar
wallifishrmn
Default LS6 Engine Rebuild Question
I know one of the problems with the LS6 engine is it is an aluminum block with very thin steel/iron cylinder liners. Cracked rings or destroyed rings can score the cylinder walls deep enough that they can't be cleaned up with .010 to .015 of an inch. My question is if you want to save your original engine block to keep your engine 100% original what can be done. Why can't the original liners be replaced if the aluminum block is OK. Are there any other options? With todays technology there must be a way to save original LS6 blocks. Thanks
Old May 15, 2010 | 01:16 PM
wallifishrmn
Maybe I should post this under tech/performance. Where's all the engine experts-I know that leaves me out.
Old May 15, 2010 | 01:21 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I really wouldn't worry about keeping the engine 100%, I don't think the engine numbers are recorded anywhere.
Maybe time for a nice LSX block.
Old May 15, 2010 | 01:42 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You car will never be a collectors item in your lifetime. Stop sweating all of the details and enjoy your car. With 240,000 + C5's made, there are lots of choices for replacement motors including GM.
Old May 15, 2010 | 01:44 PM
kp1's Avatar
kp1
Original cylinder sleeves are cast into the engine. not pressed. It can be resleeved, but it is far too expensive. When you get your block out, have a machine shop check it to see if it can be oversized. If you have a cracked or broken cylinder sleeve, toss it and buy a forged short block or one of the LS6 long blocks for about $3500 delivered.
Old May 15, 2010 | 08:38 PM
wallifishrmn
Does anyone know for sure whether the engine has the car's serial number on it or a casting date. Why do some people get upset when someone tries to keep their corvette 100% original. Every corvette is collectible in my opinion. Did someone in 1980 think the 1967 big block would be worth $130K in 2010?
Old May 15, 2010 | 10:58 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It does not work the same way, but yes they have unique numbers on each car.
Old May 15, 2010 | 11:11 PM
PAmotorman's Avatar
PAmotorman
the older corvettes are worth money because there are lots of rich guys now that wanted one back then when they were kids and could not afford one but now days anyone who wants a corvettes buys one and they will not be wanting for one in 40 years
To LS6 Engine Rebuild Question
