Removing Interior Panels
Old May 17, 2010 | 04:11 PM
Superman09's Avatar
0Superman09
Former Vendor
Default Removing Interior Panels
I have to check out some wiring for my 12 disc changer and need to remove the interior panels along the passenger side to get the wires free. I do not want to break anything, so whats the way they panels remove? Maining the "kick panels" I thin kthey are called, which run along the bottom by the doors. Thanks!
Old May 17, 2010 | 04:21 PM
BHRZ06's Avatar
BHRZ06
Your going to laugh but no screws they are just pushed in place via retaining clips. Use a plastic pry tool and locate the clips along the sill and pull em out should not take ya more than a minute or so. cracks me up how these are held together
Old May 17, 2010 | 04:36 PM
Superman09's Avatar
0Superman09
Former Vendor
haha good deal. I assumed that since I wasn't seeing any screws but figured I should ask before I started yanking! Thanks!
Old May 17, 2010 | 05:35 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Actually it was probably a good idea to do it this way since there is no metal back there just a thin SCM formed tub that is glued in. The front seating compartment is a combination of steel and aluminium sandwiched balsa wood floors.
That's why it is recommended to use weleded in roll bars on C5's as the roll bar will just go right through the floor if it's not welded to the frame.
Just be careful pulling off the panels not tho break the metal clips or tabs on the back of the panels.
The wiring for your CD run from the passenger footwell back.
Old May 17, 2010 | 07:18 PM
Superman09's Avatar
0Superman09
Former Vendor
Thanks!
Old May 17, 2010 | 09:14 PM
robsc501's Avatar
robsc501
Hi There;
Use the search feature & type in: how to fix a door lock. c/f Member Bakersfield did a nice step by step procedure with pictures.This will be a big help to you.
robsc501
Old May 17, 2010 | 09:20 PM
jrprich's Avatar
jrprich
Also go easy as you pull up the sill covers......the plastic tabs that hold them on break off REALLY easily........ask me how I know
Old May 17, 2010 | 09:22 PM
CurbsEnthusiasm's Avatar
CurbsEnthusiasm
For about $5 Harbor Freight has an upholstery tool kit, just plastic tools. I used them yesterday when pulling the trim for carpet removal, they worked like a charm.
Old May 17, 2010 | 10:34 PM
robsc501's Avatar
robsc501
Hi There;
I was wondering if you had the item number for the h/freight tool set?
robsc501
Old May 17, 2010 | 10:38 PM
CurbsEnthusiasm
Originally Posted by robsc501
Hi There;
robsc501
Item # 67021
$7.99
I used the 20% coupon from my motortrend!
Old May 18, 2010 | 04:49 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i have been pulling the interior apart and replacing it each weekend as i work on a radio head unit and double d bezel mod. it comes apart and goes together with less nut and bolt (or screw) type fasteners than a basic erector set windmill (you have to be a bit older to get that reference, lol). it all just pulls apart and then just presses back in place with the clips that are formed as part of the trim piece being removed. any plastic trim tool will help, but it isn't really necessary. just grab an edge and gently work it up and away from the body part it is seated to.
Old May 18, 2010 | 10:08 PM
robsc501's Avatar
robsc501
Hi There curb;
Thanks for the item number. I'll pick one up next time I get to h/freight
robsc501
To Removing Interior Panels
