These are only available for the 01-04 air systems correct? Do they come with the air for earlier vettes (99's)? If not, is there an extension for sale somewhere that will be able to hook the air system up for my 99? where could I get it? I'm not really interested in removing it at this point. Thanks in advance.
Any body know what thaverge HP and Torque gains are wih this system?
There are many comments about the sound, but hard to track down average power gains?
Each car is different but I typically see realistic 20-35 rwhp and rwtq gains. What is big though is the power gained through the mid-range. I have seen gains of torque in the power band near 45 before!
Correct, 01-04. I myself had a 1999, and came up with 3 options for 97-00 cars using these headers.
1.) Use the supplied block-offs and delete the AIR system.
2.) Replace the passenger side AIR tube with one from a 01-04 car, (drivers side is fine)
3.) Cut your passenger side AIR tube and extend the necessary distance with a type of hose. I do not recommend this, but have had customers do this in the past with great success! Fuel line is one example I remember someone using.
Would I be able to cut the air tube connector off the headers, have it filled, and re-welded the air tube connector on the passenger side one tube down to be able to hook it up to my air tube system of my 99?
Okay, I'm in...PM me best price shipped to 92688 for the catted system please
Certainly, but I think the options I posted would be much easier!
Hey Jon , should I buy header bolts are use the bolts that are on the manifolds now. In the past I have always used header bolts and a drop of locktight , what do you recommend I should use on these.
Just a heads up that we will be closed this coming week from Sunday dec. 16 through Sunday dec. 23. I will be unavailable to answer PMs, emails, phone calls until after Sunday the 23rd. Any orders placed while we are away will be processed and shipped in order received after the 23rd. If you need anything else, I will be back in touch after the 23rd ASAP in the order received! I apologize for any inconvenience and wish you all happy holidays!
Ok, i'm pretty sure i'm going to go with these headers, feedback seems to be great. I want to have everything I need to do the job correctly, so what exactly would I need to complete the install?
I have a 01 Z06, from what I gather, you reuse the header bolts, but it seems like it is a good idea to get new GM header gaskets?
Anything else? I'm thinking of changing the plugs and wires while i'm at it, any other thoughts? Car has 27k miles if that means anything.
just installed header on my 98 C5 6PD ,had it dyno tune this week, previously installed Ls6 intake GM HOT CAM blue springs, comp. push rods, vairaram intake & bbk . SOUND SUPER
385.4 RWHP
P.S. I did move my air tube on rt header back where it would bolt up to A.I.R. PIPE
You can reuse your bolts or run new, nothing imperative there. The gaskets I would run the GM ones. If yours are okay when you remove them you can reuse them. If they have developed a leak already or look rough, I would run some fresh GM ones. Other than that you should be good!
