Finally getting some muscle under the hood!
After a long time of consideration, saving and research, I've decided to put some real power under the hood. My 97 LS1 is the weakest LS motor installed on any corvette. A complete exhaust, intake, 1.8 rockers and tune yielded a semi-healthy 328HP at the wheels, but i think i can do better.
I didn't want to do anything drastic to the motor for fear that i'd blow up my aging transmission, but earlier this year my trans died anyway and Frank's Vettes rebuilt it with heavy duty parts and a shift kit. Now that the drive train is all heavy duty (i have the 3.15 gear option from the factory) I can finally focus on the motor.
The parts list:
- 243 heads w/ valve covers and coil mounts
- Custom SDPC cam: 221/226 .565/.560 114
- powerbond (new generation) under drive pulley
- new pushrods
- new lifters
- new oil pump
- new timing set
- new valve springs
- new misc gaskets/seals
The Plan is to get rid of my engine's "asthma" The cam profile is designed for maximum torque towards the bottom end. My 1.8 rockers will carry over to the 243 heads. I'm hoping this plus a re-tune (street not dyno) will give my that low end SOPT rating I've been after. Frank's Vettes will be doing the install. SPDC will be supplying the parts
Stay tuned for engine **** and install updates.
The parts list:
- new pushrods
- new lifters
- new oil pump
- new timing set
- new valve springs
My final Mustang dyno numbers were 416 rwhp/392 rwtq. You will be very happy. First you'll do this , then this .
FYI, I installed the 3:42's a while back and my hwy mileage is a solid 25 mpg (when held at 90 mph for a mile or two). .
Good Luck.
Former Vendor
St. Jude Donor '08
Normally I'd agree, but I have an aftermarket alternator that already has a smaller-than-stock clutch pulley. I idle at 13.5-13.8 all day long at night with everything blaring and all the lights on.
