antifreeze
Old Jun 4, 2010 | 06:55 PM
Joe Babe's Avatar
Joe Babe
Default antifreeze
Whats the best antifreeze to use in a 2004 vette? Thanks for your help!
Old Jun 4, 2010 | 07:10 PM
jrose7004's Avatar
jrose7004
Dexcool I believe is what's supposed to be in there.
Old Jun 4, 2010 | 07:11 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I 2nd the Dexcool.
Old Jun 4, 2010 | 07:22 PM
hotwheels57's Avatar
hotwheels57
DEXCOOL is just fine despite the old (some was/is exaggerated) horror stories from the late '80s and early '90s. Maintain an air tight, clean system and it'll work as intended.
If the name still worries you, many of the major manufacturers offer extended life (orange) antifreeze products now. PRESTONE is popular.
Don't use green unless it's specified safe for aluminum components!
Old Jun 4, 2010 | 07:51 PM
jrose7004's Avatar
jrose7004
We have a motion and a second, all in favor say "AYE"!
Old Jun 4, 2010 | 08:36 PM
cruisemon's Avatar
cruisemon
Aye.
And use distilled water.
Charlie
Old Jun 4, 2010 | 09:00 PM
corvettedaddy11's Avatar
corvettedaddy11
I 3rd tha Dexcool! That doesnt sound right!!
Old Jun 4, 2010 | 11:06 PM
bighank's Avatar
bighank
Default Dexcool but don't believe the 150000 mile claim
Dexcool is supposedly good for 5 years OR 150000 miles. Mine looked very murky at only 40 or 50k. I flushed out system with running water while draining radiator and adding water to the system after first draining all I could from the radiator. Stopped engine and drained as much as possible and repeated several times till it ran out clear.
Don't ruin your engine for $25-$30 of antifreeze.
Have 80k on now and will drain and refill this summer.
BIGHANK
Old Jun 4, 2010 | 11:08 PM
LT1driver's Avatar
LT1driver
dexcool for me
Old Jun 4, 2010 | 11:32 PM
Oldvetter's Avatar
Oldvetter
Dexcool is great. I have changed it twice in my 1998 C5, it was very clean both times. I always use distilled water with Dexcool, although you don't have to.
Problems (thick, muddy) come when air gets in system, as in when you have a leak. If you start loosing coolant, check it out and fix it. Also bad gaskets caused early problems with Dexcool.
Old Jun 4, 2010 | 11:52 PM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
Dexcool, worked in my 02
Old Jun 5, 2010 | 11:18 AM
killain's Avatar
killain
Oldtimer
Oh come on now. There is NOTHING wrong with the chemical construction of DexCool. Flush your system, and fill 50/50 with DexCool and drinkable water and so long as you don't have any leaks, and the reservoir doesn't go below the low fill mark, your set for the next five years. A whole lot of the problems people have had in the past is due to poor maintenance, or in the V6 engines it was a poorly designed intake maifold gaskets and or inferior V6 3800 intake manifold cracks. But that's not a fault of the DexCool.
Old Jun 5, 2010 | 11:21 AM
VinnyT's Avatar
VinnyT
Dexcool, even though they don't use that name anymore. (Bad publicity)
Old Jun 5, 2010 | 02:56 PM
Joe Babe's Avatar
Joe Babe
Thanks guys
Old Jun 5, 2010 | 11:57 PM
DexCool is fine - just change it at the proper intervals.
Old Jun 6, 2010 | 12:03 AM
H1999z06's Avatar
H1999z06
Green for me. I heard dexxool causes to many problems.
To antifreeze
