Gas Station Pump Problem
Old Jun 9, 2010 | 05:07 PM
soada101's Avatar
soada101
Default Gas Station Pump Problem
I have 03 vette stock....when i go to any gas station and try to put gas the pump keeps cutting off as if its full....i take pump out of tank put back in it goes for a couple of sec then does again... ive tried shell mobile valero racetrack... all diff places and all do it.. .any suggestions?
Old Jun 9, 2010 | 05:26 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Has it always done that?
Try pumping slower. Some pumps deliver fuel to fast and cause the problems.
On the other hand (and this is a reach) perhpas your siphon pump isn't transferring fuel from the driver side tank to the passenger side tank quickly enough and you really are filling it up (just on one side).
(I told you it was a reach).
Old Jun 9, 2010 | 05:29 PM
soada101's Avatar
soada101
it didnt at first but until a couple of months ago... if i go slower it does do better then if i just hold the pump at full blast! i can fill tank all the way up to full just takes a while....
Old Jun 9, 2010 | 05:44 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Mine does the same quite a bit.
What I do it rotate the entire handle 90 degrees and it pumps fine. I find if I move the handle towards the rear of the car it pumps with no issues. Not sure why... but it works ok for me.
Toque
Old Jun 9, 2010 | 05:47 PM
soada101's Avatar
soada101
so pump the gas upside down?!?!?!?!?
Old Jun 9, 2010 | 06:01 PM
Toque's Avatar
Toque
No ....... upside down would be rotating the handle 180 degrees from the way you would normally pump gas in your car.
Rotate the handle towards the back of the car. 90 degrees from the way you would normally pump gas in your car.
Toque
Old Jun 9, 2010 | 06:04 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Problem is your 91 octane winds up as 16 octane so until the gas turns right side up again the car will run a little rough.
If you search in the Tech section I believe some people posted similar symptoms with the tank venting system causing a problem.
Old Jun 9, 2010 | 06:07 PM
soada101's Avatar
soada101
haha guys.. just woke up! cut me some slack.. but reading that it was pretty funny lol hahahaha thanks guys!
Old Jun 9, 2010 | 06:09 PM
Nick1's Avatar
Nick1
The 180 degree method has worked for me although I seldom have this issue with my '04. I had a Jeep with that problem and the upsidedown method worked pretty well.
Old Jun 9, 2010 | 06:16 PM
thechosenone's Avatar
thechosenone
Just some helpful tips!
1. Fill up with gas when it is cool outside. The best time to get gas is in the morning when it is cooler outside. Service stations store their fuel tanks below ground. If the ground is cooler the gasoline will be more dense. Heat causes gas to expand, so if you are getting gas when it is hot outside then you may not be receiving a complete gallon, even though the pump indicates a gallon. The specific gravity and temperature of fuel is very significant. This includes diesel, gasoline, ethanol, jet fuel, and other petroleum products. Each truckload of fuel is temperature-compensated. This is done so that the indicated gallon gage is actually the amount pumped. Even the slightest rise in temperature makes a big difference for businesses. The problem is that service stations don't have temperature compensation at their pumps. That's why the outside temperature can make a difference in how much fuel you get.
2. Don't buy gas if a tank truck is filling the station's tank at that time. We have all seen the big tank truck in the parking lot at one time or another. When these tank trucks deliver the gas sludge and dirt is being stirred up in the tank. So, if you are filling up at the time you might be putting some of that dirt into your vehicle's tank.
3. Don't wait until "empty" to fill up. The best time to fill up is when or gas tank is half empty. The more gas you have in your tank the less air there is in your tank. Gasoline evaporates fast, and it will evaporate even more rapidly when it is warm. Gas tanks are equipped with an internal floating roof membrane to serve as a barrier between the atmosphere and the gas. This minimizes evaporation, so you'll want to fill up more often.
4. Pump gas on the "slow" setting. Usually, the trigger on the fuel pump will have a fast, medium, and slow delivery option. You need to use the slow setting. Using the slow setting will reduce the vapors created in the process of pumping. The hoses at fuel pumps are corrugated. These corrugations act as a return path for vapor recovery from gas that already has been metered. At the fast pumping setting, the agitated gas contains more vapor. This vapor is sucked back underground into the tank, and this causes you to receive less gas than what the pump indicates.
Old Jun 9, 2010 | 06:26 PM
kc-griz's Avatar
kc-griz
I find that if the pump keeps tripping off on high flow, I back the nozzle out an inch or so from fully in and lock it in at the medium flow setting. Has worked every time for me.
Old Jun 9, 2010 | 06:43 PM
steve8's Avatar
steve8
Back it out a little bit. My Silverado does the same thing.
Old Jun 9, 2010 | 09:07 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
I have worked at a few stations in the past and they do have a good filtering system unless you go to a mom and pop station.
I don't agree with #2 above.
Old Jun 9, 2010 | 09:12 PM
socalman's Avatar
socalman
St. Jude Donor '10
I would hope so. Tankers visit stations around here every other day. We'd NEVER have clean gas to go with our wonderfully smog free cars!
Old Jun 9, 2010 | 09:15 PM
killain's Avatar
killain
Oldtimer
Usually the pump Handle/Nozzel works off pressure, once the tank is full it raises the presure and the handle kicks itself off. At least that has always been my expierence. Do you fill the tank when it's dead empty? Sometimes if you start pumping and it kicks off, pull the nozzel out a few inches and then put back in and resume filling. That has always worked for me.
Old Jun 9, 2010 | 09:17 PM
Mr.Bill's Avatar
Mr.Bill
I remember this being passed around a few years ago on the net...lol
Old Jun 9, 2010 | 09:41 PM
o2z51's Avatar
o2z51
I get this on my 02, like stated filling at an angle does the trick.
To Gas Station Pump Problem
Old Jun 9, 2010 | 09:44 PM
thechosenone
Yeah my uncle sent it to me in a E-mail. But yes you are correct for the old time gas stations #2 would apply but for most places it doesn't. But the rest is very helpful. But no filtration system is a 100% so even tho they work 99% of the time I just wouldn't wanna be that 1%. And I only fill up in the morning or at night unless im traveling. I never go under a quarter of a tank my dad told me not to go under when I was a kid so to this day I hardly go under a quarter.
Old Jun 9, 2010 | 10:47 PM
johnson-rod's Avatar
johnson-rod
I think it's the gas station pump that is the problem. I had that problem at one station only. He tried to convince me it was the car. I went down the block and filled it without problem. I've been filling it at gas stations all over the state for years with no problem but the one station. (Actually the attendant must fill it. I'm in New Jersey and by law can't fill my own tank - its too dangerous)
Old Jun 9, 2010 | 10:55 PM
thechosenone
Haha when I was a kid we had 1 full service gas station where I lived and I always thought it was cool. And the guy that owned it became good friends with my family. But im pretty sure your gas is cheaper and thus the extra money for for full service weighs itself out to the average gas prices in the US. And I believe Oregon dose the same thing. But I do think this is a good thing for people who don't check there fluids ofter.
