Pulled Codes and need TS help please
Old Jun 12, 2010 | 03:41 PM
96mogt's Avatar
96mogt
Default Pulled Codes and need TS help please
Hello about two weeks ago i was going over a set of railroad tracks making a right hand turn and the road was wet and it went over the tracks and slide for a sec and grabbed. Once i was going straight I had the TCS and ABS light went off. So i thought i must have jarred something loose in the rear end that has to do with it. I wasnt speeding around the turn, trying to showboat or anything, the roads were wet and it broke loose when it got onto the tracks of the railroad. So i pulled the codes and this is what i had
TCS- 1243H -- BPMV Pump motor stalled
BO RFA- U1096H Loss of Comm with IPC
U1064H Loss of Comm with BCM
U1016H Loss of Comm with PCM
Where do i start?? How do i troubleshoot this? thanks in advance , Jay
Old Jun 12, 2010 | 03:53 PM
Bill Vett's Avatar
Bill Vett
If you don't have any codes that have a C then I wouldn't worry. The lights go off to warn you they the AH/TCS was needed to control you car. Check the battery connections and grounds but with no current codes just drive and enjoy.
Old Jun 12, 2010 | 03:57 PM
96mogt's Avatar
96mogt
They stay on all the time though, both ABS and Traction control. Jay
Old Jun 12, 2010 | 04:07 PM
87SAM's Avatar
87SAM
Yep, the C1243 will get you. Will start off intermitted and eventually will be there full time. First try checking the ground connection by the BPMV. Could also try looking for wet roads and try to activate the active handling to exercise the pump motor. This would only work if the fault is not active at the time. Others have stated that they put the car on jack stands and get the wheels spinning and apply the brakes to activate the pump. At some point you may well need a new pump.
Old Jun 12, 2010 | 04:31 PM
DeeGee's Avatar
DeeGee
The loss of comm codes can be caused by a number of power glitches and are nothing to worry about.
First of all clear down the H (history) codes and see if anything comes back. My guess is they won't. If so you can rest easy. If the BPMV code comes back we can dig deeper.
Old Jun 12, 2010 | 05:01 PM
96mogt's Avatar
96mogt
Ive reset it multiple times and it comes back.
Qcksilverc5's Avatar
Qcksilverc5
Ditto !~
Old Jun 12, 2010 | 06:29 PM
87SAM's Avatar
87SAM
In addition to the ground by the pump, check the wiring bundle from the EBCM, the one which passes in front of the cooling fans. Also check MaxiFuse 52 in the underhood fuse box.
Old Jun 12, 2010 | 06:51 PM
96mogt's Avatar
96mogt
Ok will try. Where is the pump at?? Jay
Old Jun 13, 2010 | 03:28 PM
DeeGee's Avatar
DeeGee
You say it comes back but you're posting a C1243H. That's a history code. Are you seeing a "C" code too? An H cant set without a C first
Old Jun 13, 2010 | 07:05 PM
96mogt's Avatar
96mogt
Correct it keeps showing the H Code. Jay
Old Jun 13, 2010 | 07:14 PM
bhoch's Avatar
bhoch
Jay, did you go through the procedure to clear the currently displayed codes? Once done, there really should not be any codes at all displayed when you go through the readings;at least until you start and drive again as one may resurface, of course.
Old Jun 13, 2010 | 07:23 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What year car do you have ?
Old Jun 13, 2010 | 07:29 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Same trouble with mine -I was able to fix it as outlined in the thread so follow the pages up, you can also call me at 661-406-7516 -
Your problem is in the clip Male/Female parts - you'll see
See the Electrical Thread here: Go to post #806 on Page 41 (This should be the direct link:
http://forums.corvetteforum.com/c5-t...n-long-41.html
Tech Section:
http://forums.corvetteforum.com/c5-tech-1/
Thread (Sticky):
http://forums.corvetteforum.com/c5-t...tion-long.html
Thanks,Matt
Old Jun 21, 2010 | 06:07 PM
96mogt's Avatar
96mogt
Tech Section:
Thread (Sticky):
Thanks,Matt
Hey Matt,
Thank you I will look into it this weekend and get back to you! Jay
Old Jun 21, 2010 | 07:34 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I seem to get the loss of comm codes every 3 months, I always clear them and I am good to go. I figure they come up if I get a power glitch.
Old Jun 21, 2010 | 11:43 PM
madmatt9471
Hey Matt,
Sounds good!
Thanks,Matt
To Pulled Codes and need TS help please
Old Jun 24, 2010 | 10:46 AM
96mogt's Avatar
96mogt
Sounds good!
Thanks,Matt
Hey Matt,
Got a question, where is this harness located that i need to disconnect? Jay
Old Jun 24, 2010 | 04:30 PM
madmatt9471
Hey Matt,
Jay,
The ebtcm ABS Module on the '97-'98 (early model) are located in the rear, f you look at the pics in the thread above with the links I gave you it will show it.
Now if you have Late '98 to 2004 then it is located up front and right in front of the power steering pump -
It is the large clip that goes into it and it has a big handle to "PULL" down in order to unclip it from he module.
Then you can inspect it and make the necessary adjustments to the female part of the clip (like in the above thread)
Thanks,Matt
Old Jun 24, 2010 | 05:17 PM
12png's Avatar
12png
Check your grounds on top of frme under hood. They will be near the front, close to radiator. Don"t just check for continulty, pull off and clean. Apply diaelectric.
You can also disconnect battrey for about 3 minutes, this will reset your computer to default.
Good Luck
