RPM question
HP Tuners is one of the best to use, your local Vette shop should use this and can jog it on the dyno and reinact your conditions or do it on the stree/freeway safely. It almost sounds like it is going into limp mode.
Have you tried to pull any codes off the PCM from your DIC? (Sorry if I missed it)
Thanks,Matt
Just find a local Corvette Late model GM shop that has a dyno and HP Tuner software. The tuner will know what to do and it should be relatively inexpensive.
Thanks,Matt
Try this - put the car in second gear and try seeing what happens when you hit wide open throttle. Does the car keep going up to 5k+ RPM's when locked in second? Or does it bog down at 3k like always?
If it bogs down at 3k in 2nd gear, that would point toward a fuel issue rather than just a shift point issue.
Second - try this (already said it, but you didn't do it)...
Take your car on the freeway
Get up to 70 mph
Hit Cruise control to maintain 70
Change car into 3rd gear
Look at the RPM's and report the exact RPM's back here.
This will tell us if the rear end ratio has been changed. If it was and the person never reprogrammed the computer, that could cause shift point problems.
Just a couple things worth looking at before you pay someone else to do it.
I am not very familair with the automatic transmission so i am kinda scared to change to 3rd gear while cruising on highway.
I tried driving with TC off. it still shifts at 3000 if i floor it. if i gradually apply gas then only it goes up to 5500
i could go into a long description about how the OD gears turn an opposite direction. and all that but It's easier with pictures. when really racing/getting on it in the street letting off the gass and putting it in 3rd is what should be done ( the car will still use 1&2 when it needs to it just won't go into Over Drive)
Sooo . . .when it see's this, and thinks the rears are slipping, it reduces power ( I was under the impression it did this by retarding the ignition, not sure about reducing the throttle opening, but either way) rpms drop....as you are seeing.
What people do when they want to run the same size rims all around is that they choose a tire sidewall height that results in the required difference between the overall height of the front tire/wheel combo and the rear (you want about an inch difference). So basically with 20's all around with the same sidewall you are going to need to change one set of tires. Either a smaller sidewall on the front tires or a larger one on the rears.
Review this post for a better explanation
http://forums.corvetteforum.com/c5-g...ah-issues.html
You may have more than one thing going on, but Im pretty confident that "there will be no peace in the valley" until you address the wheel/tire set up you have.
Dont get nutz over this
Yes, the car isnt performing as designed, but it was modified out of design. If you are driving it like a regular car (not like a vette) you probably are not hurting anything until you can get it fixed.We went over the TC system retarding the ignition when it thinks there is wheel spin, but the AH system is also in play in any situation other than direct straight line movement when it senses wheel speed differences, lateral G's, yaw values and steering wheel position (yes, its monitoring this stuff all the time) that dont fit in the values stored in the table it will attempt to correct your line (the path of the vehicle) by differential braking of each wheel independently (think of skid control....on steroids).
So if you were in a left hand turn and it saw high lateral G, and excessive left yaw it might apply just the left front and/or rear brakes to different degrees in an attempt to get the vehicle back into controlled configuration.
Why mention all of this? well just to answer the "can I hurt anything by using it this way" question. Other than loosing control from a malfunctioning AH system due to the altered data going in because of the wheel problems above, you may also be experiencing uneven brake wear if your driving it hard in your present configuration. Regular driving, probably isnt hurting anything.
Yes they will fit and yes the Chevy guy is right. Your overall tire height is the right ratio for your car. This is NOT the source of your problem.
but you know what I mean) to not cause AH/TC problems?And believe me, Im not challenging you here
Im here to learn, what do you think is going on?
Im here to learn, what do you think is going on?Hope this makes sense to you and helps.
I noticed whistling sound on idle coming from underhood. It sounds more like a cold air intake. I also have throttle response lag around 1/2 second.
Slim....Im out...sorry guy
Thanks Doje
