If you just push the button you will see the rear of a C5 in yellow on the dash by the speedo, That means the TC and AH is off, If you only want to turn of TC hold the button in for 15 secs and it will say Comp mode in the DIC.
thanks.its raining right now i will turn tc off and drive it in morning
Originally Posted by Blew by you
Sounds like some serious engine problems, i would get it checked out immediately!
car has only 30k miles. what kinda serious engine problem can it have?
Originally Posted by KenShores
Turn TC off, put it in 3rd, hit the gas and stay on it. It should go to about 6k and shift. After go get uo to speed, shift to D.
get a trans tune, 2.
6000 rpm in 3rd gear? are you serious. the rear end feels so light. i feel like its going to go sideways even at 3000 rpm
I got to ask bro,
Can you please elaborate on what kind of ENGINE PROBLEMS's?
Your statement sounds like a huge blanket statement and very knowledgable, I think you might owe an explanation of some sort.
If indeed he does have serious "ENGINE" problems as you state then I believe you need to state what they are or if you have first hand experience with the same problem please offer a solution and not just some off the wall statement to make your posts go up.
This is the Tech section and owners need sound serious advice on how to repair a problem and not cause more with statements like yours.
Mr Bill is on to somthing!!!!! I almost bet that the larger wheels are the problem.. On my handheld tuner it has wheel size ajustments for speedo and shift points for adding larger wheels. By the way in bone stock form my 2001 a4 shifted at 5,800 at wot no matter what i did.
It's a high performance car it's probably been driven hard! maybe too hard?, and could have some sort of engine damage, i had a 90 Z28 and let the oil get a little old and my girlfriend drove it hard and after awhile it wouldn't rev out, just like what he describes, i'm no mechanic just stating an opinion just like everyone else, why is everyone so quick to jump on people's **** on here? take it to a mechanic!!!, most people like me on forums don't know ****!.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Your problem is not a traction control issue.
First of all, your car would show on the DIC screen "TRACTION CONTROL ACTIVE" and you have never seen that.
Secondly, even if you are so focussed on the rest of the world that you missed the message, I did a delta calculation on the tires you are using. The front to rear ratio is only 0.3% off from the factory delta. You have to be over 1.2% to fool the computer into thinking you are having slippage.
Take your car to a shop that can reprogram the shift points and call it a day.
One more thing, take your car on the freeway, put it in 3rd gear, and set the cruise control at 70mph. Take note of the RPM's, and report back here.
Ok. I think i found the problem
I drove it this morning with traction control off. I noticed following
1. If i push gas pedal to floor : it goest up upto 3000 rpm and changes gear. engine makes roaring sound and it accelerates slowly
2. if i accelerate it gradually it went up to 5000 rpm. it accelerates like a very fast
I put it in 3rd gear and tried to merge into highway and rpm went upto 5500 with traction coltrol on.
Not sure what your talking about, you make no sense at all!
your car should rev past 5,500 in any gear with or without traction control on, take it to a mechanic please!
Chevy dealership will charge me a too much money just to look at the car and tell me everything is normal.
Is it ok to drive the car like that?
I understand what you are speaking of, there is a tuning issue. You need to have a Scan File done on the Vette's PCM. This will tell a huge story as to why the shift points are off and it is not allowing proper transition of gears.
HP Tuners is one of the best to use, your local Vette shop should use this and can jog it on the dyno and reinact your conditions or do it on the stree/freeway safely. It almost sounds like it is going into limp mode.
Have you tried to pull any codes off the PCM from your DIC? (Sorry if I missed it)
Are you serious? You bought a Corvette and don't want to pay to fix it? Something is seriously wrong with the programming in your car. I would be taking it to a local shop that specializes in dyno tuning or street tuning Corvettes. Pay the $300-$500 and have them do a full tune on the car. It will run better, produce more power, get better gas mileage, and SHIFT WHEN IT IS SUPPOSED TO.
You should be fine to drive it. But don't try to romp on it and end up hurting something els. I wish I was closer I'd use my HP Tuners on it. No need to take it to the dealer.
Just find a local Corvette Late model GM shop that has a dyno and HP Tuner software. The tuner will know what to do and it should be relatively inexpensive.
I was just thinking - another possibility is a partially clogged fuel filter. If the filter is restricting fuel flow, it's just like letting off the throttle - in which case the car will upshift.
Try this - put the car in second gear and try seeing what happens when you hit wide open throttle. Does the car keep going up to 5k+ RPM's when locked in second? Or does it bog down at 3k like always?
If it bogs down at 3k in 2nd gear, that would point toward a fuel issue rather than just a shift point issue.
Second - try this (already said it, but you didn't do it)...
Take your car on the freeway
Get up to 70 mph
Hit Cruise control to maintain 70
Change car into 3rd gear
Look at the RPM's and report the exact RPM's back here.
This will tell us if the rear end ratio has been changed. If it was and the person never reprogrammed the computer, that could cause shift point problems.
Just a couple things worth looking at before you pay someone else to do it.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I believe his engine is just fine. I want to hear if he drove the car with the TC off, Haviong the same size tires front and rear will cause havick with the computer.
